Start trouble
Old Aug 13, 2003 | 01:56 PM
Wolfer's Avatar
Start trouble
My rx8 has almost 1k miles on it. I've noticed it sometimes takes 2 tries to get it started. I dont' like cranking it so it doesn't flood.
Haven't had a problem in the past it started right up. Anyone else notice this?
If it's having problems now to get started I just can't wait till winter.
Maybe it just needs more revvving.
Old Aug 13, 2003 | 02:22 PM
dcfc3s's Avatar
RX-7 Guru
You may just not be giving it enough "key" to start it. Does it typically not start when cold in the morning, during a hot start, what?
Just trying to eliminate user error from "by design".
Mazda designed it to take a little longer to crank before firing - about 1-2 seconds of cranking before the engine lights. The RX-7 was/is the same way.
Dale
Old Aug 13, 2003 | 02:32 PM
Wolfer's Avatar
Hot start after it sits for a bit. Morning starts haven't had a problem. Starts after 2 seconds.
I crank it for about 4 seconds then try again.
Maybe I should crank it a bit longer then I'm used to.
Old Aug 13, 2003 | 10:35 PM
akrx8's Avatar
factory phil
my car is the same way,starts almost instantly in the morning stone cold and when warm cranks like 2 to 3 seconds before it fires off.never owned a rotary before so i contribute it to the design.when warm i just crank till i see the white dash lights start to come on and it starts every time.
Old Aug 13, 2003 | 10:42 PM
P00Man's Avatar
uhhhhh....hello?
ive noticed, as well as some others, that it has a slight delay on starting, like you twist it, release it, then it starts
and also that it does seem to take slightly longer to start than a piston engine
________
INTERRACIAL MOVIES
Old Aug 13, 2003 | 10:50 PM
sferrett's Avatar
Whaaaa?
Hmm you haven't tried to start my jeep lately... It's got 20k miles on it now and generally takes 5 seconds of cranking (sometimes a little more) especially if you haven't started it for a while. I attribute it to building fuel pressure or something and just live with it.
My rx8 generally starts within 1 or 2 seconds of cranking, and I can't say I've noticed any difference between hot and cold starts yet. I did think it turned over a little slower than other rotaries I've had the pleasure of starting, and I'm guessing the higher compression might be the explanation for that (although could be anything - I'm sure the starter is different from the FC or FD) I have about 1500 miles on it so far and I dont recall it starting any differently back when it was <500miles.
Old Aug 14, 2003 | 11:54 AM
hmm.. try this. turn the key to the on position and leave it there for a second or 2 until the dash fully lights up. if you listen closely you here a noise from the engine, which i attribute to the oil injectors doing their job. then turn the key and crank it. it will start in about 3 seconds. i do this every time cold or warm and have not had the delay that your speaking about.
Old Aug 15, 2003 | 09:27 PM
AC TL's Avatar
Tried to start a velocity red yesterday and it took about 1-2 seconds to start.
Old Aug 17, 2003 | 09:48 AM
MikeW's Avatar
Originally posted by vaughnc
This may go away as the engine breaks in. My 1989 Convertible RX-7 doesn't have cold or hot start issues, and the engine has 122K miles on it.
I believe the starter spins the motor at 1500 rpms (vs 800rpms or so for a piston engine), so it's not a lack of rpms or cranking amps.
I'd like to know what kind of car that has a starter that cranks the engine to 800rpms. My car it is about 75rpms. (50 rpms on a cold start in the winter to 100rpms for a hot restart in winter)
Old Aug 17, 2003 | 09:51 AM
RXhusker's Avatar
Int-X 293WHP 242TQ :)
I've had the same "problem" but have decided it is an operator issue not a car issue. Now I just look at the tach and have not had a problem since. The engine is so smooth that you just can't feel it when it starts like a piston engine -- since I started using the tach as a guide instead of "feel" I haven't has an issue.
ladnarf1
Apr 29, 2021 11:53 PM
SUKIEE
Oct 9, 2017 09:41 PM
GracefulShanks
Aug 18, 2015 11:40 AM
rx8wankelrotary
Aug 17, 2015 10:42 AM
T_Mags
Jul 24, 2015 11:29 AM
