slow start?
Old Aug 13, 2003 | 11:01 AM
umpuck's Avatar
slow start?
im havin trouble kickin in from stop to 1st to 2nd....seems a lil slow compared to other cars.....but from 3rd gear to 6 the car flies!!!!!! any suggestions? such as when to shift, what rpms. or does this car just have a slow start?
Old Aug 13, 2003 | 11:18 AM
Lex's Avatar
Lex
Crap, why didn't anyone mention before that this car is slow at low speeds?
Old Aug 13, 2003 | 02:20 PM
jonalan's Avatar
Pu-36 Space Modulator
Get those revs up! It's not that slow in low gears.
Old Aug 13, 2003 | 06:13 PM
umpuck's Avatar
How many rpms when im at a complete stop to go to 1st and how many rpms should until i change to second? so far what im doing is not helping.....but w/ around 600 miles i don't want to go too high :P
Old Aug 13, 2003 | 06:18 PM
jerzeydevil's Avatar
I experienced something similiar, not necessarily from stop to first, but rather from first to second it seems to not wind up as quick. From second to third the car takes off...noticeably. It's almost as if the clutch is slipping the whole time in second and the you can feel the engagement in thrid.....For the interested few, shifts are at 8k (still babying it ). Not sure if this is related to the whole ECU thing or not, but it is noticeable the lag in second and the lurch in third.
Old Aug 14, 2003 | 11:38 AM
umpuck's Avatar
yeah that seems exactly what im experiencing right now. ANY OTHER TIPS!?!?
Old Aug 14, 2003 | 12:14 PM
seikx8's Avatar
Is this title ok?
Take that thing pass 3k rpm if you want to go fast. Anything below 2.5k will feel sluggish. Those low rpm only for crusing Sometime I have to down shift two gears to get the rpm up if I want to accelate fast.
Old Aug 14, 2003 | 05:12 PM
umpuck's Avatar
good tips....gonna give it a shot
Old Aug 14, 2003 | 09:16 PM
47samurai's Avatar
Rotary old timers
So many posts with new rotorheads. My RX3's usually never saw the low side of 3000 rpm, unless i was stopped. It is a Mazda Rotary Engine!!! KEEP THE REVS UP. Low torque is normal at the lower rev range. You wont float a valve , twist a camshaft or any of those pist-on things.
Talk to an old timer sometime.
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
dafiltafish
Aug 21, 2015 06:56 PM
Rx808BI
Aug 9, 2015 10:06 AM
arjunmshah
Aug 6, 2015 10:56 AM
