Removal of Volume Knob
Old Apr 12, 2006 | 10:52 AM
Hudson's Avatar
Removal of Volume ****
Hey folks. Just a quick question that I need an answer for. I just ordered a custom **** for my stereo ( like the one found here --> http://cgi.ebay.com/ebaymotors/RX8-R...spagenameZWDVW ) and wanted to know if there was anything special I needed to do to take off the factory volume ****. I tried the old tried and true method, just try yanking it off, but it didn't budge. Should I use a small flat-head screw driver to force it off??
Thanks ahead of time for any info!
Hudson
Old Apr 12, 2006 | 11:26 AM
StealthTL's Avatar
Arrow Pull.....
Pull, and pull some more.
A screwdriver will just chew it, and it's surround, up.
You could try a set of vice-grips with cloth around them, but there is no trick, just pull.
S
Old Apr 12, 2006 | 10:05 PM
neffjohn's Avatar
No tools needed . just pull it out
Old Apr 13, 2006 | 01:38 AM
for me it took channel locks,, and a neoprene can cooler. cut it up to protect and grip the ****.
Old Apr 13, 2006 | 01:40 AM
automaton's Avatar
I just changed mine yesterday. Pull HARD. I thought i was going to break it, but it popped off eventually.
You'll need to pry the little retainer out of the old **** and put i tinto the new one. Pulling it out isn't a problem, but you need to press it into the aluminum **** with a lot of force (hint: I used a penny so it wouldn't dig into my thumb)
Old Apr 13, 2006 | 07:12 AM
Hudson's Avatar
Thanks for the info guys. The **** should arrive today so hopefully by tonight I'll have them swapped out.
Hudson
RX8mzda
Oct 1, 2015 10:17 PM
Racingjunkie
Sep 29, 2015 05:05 PM
xAgyex
Sep 28, 2015 08:54 AM
Learners_Permit
Sep 27, 2015 07:38 PM
