cannot clear NVRAM
Old Apr 8, 2006 | 05:57 PM
cannot clear NVRAM
am trying to reset my fuel trims. i am having some major issues with power.
did the key off, hold odo button key one. test comes up on odo , turn off. then repeat.
does not work, ltft still the same.
any ideas, i am wondering if i am having an ecu issue.
thanks
Old Apr 8, 2006 | 06:03 PM
Nemesis8's Avatar
Bigus Rotus
Un-connect the battery and step on the brake pedall a few times.
Old Apr 8, 2006 | 06:16 PM
yea,
saw that. will give it a shot.
Old Apr 8, 2006 | 06:30 PM
Brice-RX8's Avatar
Yea disconnect the battery. I have never seen a car where holding the trip button did more than just diagnostics, thus I think the whole "reset the computer by holding the trip button" is just a myth.
Old Apr 8, 2006 | 07:53 PM
thanks guys.
it worked i just wonder why the other way does not. i am having some weird problems that i am trying to get sorted.
nemesis, are you running a scanlizer????
and nice job on the website..
Old Apr 8, 2006 | 08:44 PM
StealthTL's Avatar
Question Next time.....
Try taking out the top 10Amp fuse in the front fusebox, marked ECU.
Haven't tried it myself, but should work.....
S
Old Apr 8, 2006 | 08:50 PM
S
like that idea better. i just dont want there to be a next time.
Old Apr 9, 2006 | 07:47 AM
rxeightr's Avatar
M0D Squad -charter member
Did it help with your power issues?
Old Apr 9, 2006 | 10:54 AM
WTF, you don't own a scanner yet?????
Old Apr 9, 2006 | 11:45 AM
Nemesis8's Avatar
Bigus Rotus
Yep Scanalyser v1.0 and Beta v1.1 and the USB CANScan
Old Apr 9, 2006 | 07:19 PM
do me a favor next time you are out running around town in the rain... maybe a little stop and go and some highway. could you let me know what the h20 temps run.
also as a 70 mph cruise what the maf reads ~.
btw. the beta 2.1 i think it is allows 9 gauges.
Old Apr 9, 2006 | 07:23 PM
Nemesis8's Avatar
Bigus Rotus
Yep - on my way in to the office on Monday I can do it. Rain is in the forcast.
Old Apr 9, 2006 | 07:31 PM
thx, and what are the odds on the rain thing. you alway have a place to stay in sunny fla. it did rain last night for a couple of hours. first in about 6 weeks.
Old Apr 9, 2006 | 07:51 PM
Nemesis8's Avatar
Bigus Rotus
60%
Do you want me to create the same screen guages you have there?
Old Apr 9, 2006 | 07:53 PM
60%
naw,
just need the two...
Old Apr 10, 2006 | 08:20 PM
Nemesis8's Avatar
Bigus Rotus
Looks like coolant was 179F cruising at 70 MPH. Temps swing to 184F in town, and hit 208F before the thing started cooling down. Outside temp was 60F and inlet air temp was 68F. As for the MAF reading at almost 70 MPH on cruise control, looks like 38.62 grams/sec.
Old Apr 10, 2006 | 08:39 PM
excellent. thanks that what i needed.
Old Apr 10, 2006 | 09:05 PM
MazdaManiac's Avatar
Wow, your cars run hot.
Even after fairly "spirited" driving at +80°F ambient temps, my water temps seldom get over 195°F.
Old Apr 10, 2006 | 10:15 PM
Nemesis8's Avatar
Bigus Rotus
Yep - scares the hell out of me. I'm ready to change something.
Old Apr 10, 2006 | 10:18 PM
really?????
this is the info i need... mm? how high have you seen your temps?????
nem? have you had any problems with sudden power loss???
Old Apr 10, 2006 | 10:21 PM
and mm
this has something to do with the ltft ? i have asked you in the past.
Old Apr 10, 2006 | 10:26 PM
Nemesis8's Avatar
Bigus Rotus
No power loss at all - chirps tires in 2nd and 3rd. My LTFT is 5.5% right now. It pretty much stays right there.
Old Apr 10, 2006 | 10:30 PM
pm
Old Apr 11, 2006 | 02:22 PM
I've hit 210° or so if I idle for long periods of time at ambients over 90°.
You can see 225° or higher and still be alright since the coolant pressure is so high.
You just aren't making peak power and are closer to the knock point.
LTFT probably won't be affected much by your coolant temp, though it might figure into the temp control strategy. I dunno.
Hunterkelley24
Jun 14, 2022 08:32 AM
snowrydr01
Nov 23, 2015 09:40 AM
GK1707
Sep 27, 2015 07:33 PM
Stubbs
Sep 27, 2015 04:06 PM
drlubell
Sep 26, 2015 11:58 PM
