Rough idle, anybody else?
Old Aug 10, 2003 | 04:24 PM
Hercules's Avatar
Hi guys....
I've noticed excess vibration while I'm idling in traffic.. being that I'm almost ALWAYS driving city (and thus, my best gas mileage has been 17mpg), it's really irritating.
Anybody else have this problem? Should I take it in?
Old Aug 10, 2003 | 05:25 PM
r0tor's Avatar
the car i test drove shook a bit at idle too... especially the shifter
Old Aug 10, 2003 | 06:30 PM
P00Man's Avatar
uhhhhh....hello?
yeah, my shifter has the shakse at idle also
________
Weed Vaporizer
Old Aug 10, 2003 | 06:34 PM
brothervoodoo's Avatar
RainMan is Back
My shifter shakes a little but not enough for me to worry about. What is your definition of "rough idle" and how bad does your shifter shake?
Old Aug 10, 2003 | 06:35 PM
BRealistic's Avatar
Ahhh, the dreaded rough rotary idle. By lightening up the rotors in the Renesis, I am suprised this hasn't been more of a problem. Considering how important the balance of the rotors are, and the Renesis using light rotors, would even the slightest carbon buildup cause a vibration at idle? I keep hearing about the rich a/f setting at high rpm, which will leave alot more unburnt fuel in the engine, especially with exhuast side porting instead of periphial porting. Wasn't that the point of the side exhaust port- to aloow the unburtn fuel to stay in the engine? This could also lead to fouled plugs-- either way, maybe it is time to start mixing some MMO in the fuel for your Renesis?:p
Old Aug 10, 2003 | 10:46 PM
Hercules's Avatar
So what should I do? Should I take it in, or is it something thats normal?
Old Aug 10, 2003 | 10:50 PM
eccles's Avatar
Prodigal Wankler
I guess you could take it in and have them put it on a scope, but it it really was misfiring (and I can't think what else would be causing a vibration at idle) I would expect it to throw a code.
Old Aug 10, 2003 | 10:53 PM
akrx8's Avatar
factory phil
my car only has 130 miles but i have noticed something odd,the car i test drove first before mine arrived had the shifter shake at idle but did not idle rough.my car i bought yesterday does not idle rough either and still has the shifter shake but is only half of what the first car i drove was(if that makes any sense)by the way,i love this car.
Old Apr 5, 2012 | 10:27 PM
M3G4T7ON's Avatar
Could the shakes be caused by spark plug/coil going out?
My car shakes at idle slightly and almost skips a beat every 10-20 secs, yet no code other than the evap code i havent addressed yet.
Old Apr 6, 2012 | 11:38 PM
Raves44's Avatar
The shifter shakes because it is a top loader transmission and that is the vibration you feel in the transmisison. My dad drives the Miata MX-5 and the shifter does the exact same thing so I would not worry about it.
Old Apr 7, 2012 | 01:34 AM
ferny24hr's Avatar
Hi everyone,
my rx9 Idle stall in the morning after 20 of driving stops.. I have change the ignition coils, MAF sensor, new spark plugs.. does anyone has and idea of what this could be?
please help.. thank!
Old Apr 7, 2012 | 01:38 AM
dozer's Avatar
on his 3rd rx8
Originally Posted by ferny24hr
Hi everyone,
rx8
Old Apr 7, 2012 | 08:58 AM
Noxity's Avatar
Be Nice. <3
Originally Posted by Hercules
Hi guys....
Weelllll. A shaking shifter is normal. As long as it is idling at 900-1k and not dropping that's normal too. If it is shaking more than you like, get the carbon cleaned. If that doesn't help, check the engine mounts. Otherwise get used to it. C:
Old Apr 7, 2012 | 09:48 AM
You do know the original post you quoted is almost 9 years old?
Old Apr 8, 2012 | 08:43 AM
Noxity's Avatar
Be Nice. <3
Then I guess we should be responding to this guy, since he's the one that bumped it up. :O
Old Apr 8, 2012 | 09:32 AM
ferny24hr's Avatar
Originally Posted by dozer
rx8
yes is a rx8
Old Apr 9, 2012 | 12:47 PM
milkis's Avatar
yes, and my rough idle was fixed with new spark plugs. had 36K miles on original. prior to this, like op stated, i had rough idle with slight vibration every 15 sec. and when it does the rpm drops about 200 and back up.
Old Apr 20, 2012 | 10:39 PM
M3G4T7ON's Avatar
Wow thats excactly my problem where it shakes some,but more importantly drops 200 rpm every 5 seconds or so.
Motor mounts are very common to go bad and for people with shakes but no idle drop that seems to be the culprit. I thought if the plugs are bad it would pop a misfire code?? hmm can you buy plugs without the coils or are they a package deal?
Old Apr 22, 2012 | 03:56 PM
LytHka's Avatar
Amazon Amazon
Amazon Amazon
Cheapest you will find anywhere.
theblinkof
Oct 4, 2023 05:24 PM
Danield97
Sep 30, 2015 05:59 PM
Quiggs321
Sep 30, 2015 05:34 PM
