Gulf RX-8 Forum Serving TX, OK, AR, LA, MS
Flywheel install locations in the Woodlands/Conroe area
Old Mar 22, 2006 | 04:25 PM
HCTR154's Avatar
Smile Flywheel install locations in the Woodlands/Conroe area
I am going to purchase a lighter flywheel soon. Probably the ACT streetlight from Rotary Performance in Garland.
I am in the Woodlands/Conroe are and would like to know if there are any reliable shops around that will not try to rip me off when I go to get an install.
Also, what else should be replaced while doing this? Is it necessary to replace the clutch, plate and throwout bearing?
Thanks.
Attached Thumbnails Flywheel install locations in the Woodlands/Conroe area-rx-8-2.jpg
Old Mar 22, 2006 | 08:29 PM
buzzardsluck's Avatar
cant help you on the shops but i would think it would run $200+ in labor(just guessing 3 hour job @ $70 an hour). dropping a tranny just sucks.
i also dont think you need to replace anything, im assuming you have less than 30k. your clutch and pp should last for quite some time. have you tried a search on this subject?
Old Mar 22, 2006 | 10:19 PM
HCTR154's Avatar
Thanks for the info. I tried a search and I always seem to get to much info to search through, half of which never seems to have anything to do with swapping a flywheel.
Old Mar 27, 2006 | 12:34 PM
rotarygod's Avatar
Give Curt a call at Tracktime Performance. They are by Willowbrook mall which isn't too far from there. While you're there you can go play with the track cars!
713-907-0345
Old Mar 27, 2006 | 02:27 PM
HCTR154's Avatar
713-907-0345
Thanks, I will call them.
xAgyex
Jun 3, 2026 03:47 PM
dmengel
Feb 16, 2016 09:47 PM
RA32425
10
Sep 8, 2015 08:53 AM
EfrainOlivares
Aug 14, 2015 06:17 PM
