Cluch noise
Old Mar 22, 2006 | 08:13 AM
cezacho's Avatar
Cluch noise
Hey guys
I was wondering if any of you could help me with this problem. The cluch makes a little noise when in neutral. It's barely noticeble. When I press the pedal it goes away. Is it normal for cluch to make noise like that?
Old Mar 22, 2006 | 08:29 AM
yiksing's Avatar
the giant tastetickles
Search, search, search
This has been covered way too many times...
Old Mar 22, 2006 | 08:31 AM
Go48's Avatar
This has been discussed many, many times before on the forum. It is not the clutch, it's the transmission main shaft rolling on it's bearings. Normal for this car. When you press on the clutch pedal, the main shaft is disengaged from the engine and no longer turns.
BTW, welcome to the forum! The search function and reading, reading and more reading is your best friend here. Lots of very valuable information on this forum on the car. Check out the DIY section particularly.
Old Mar 22, 2006 | 08:37 AM
cezacho's Avatar
thanks guys...I did the search for "cluch" and none of that came up...what fraze should i type in?...oh and another thing is that i've never heard it before...i have 35000 miles on it and i started hearing it recently...and should i cancel my appoitment with the dealer then?
Old Mar 22, 2006 | 08:47 AM
Go48's Avatar
Yeah, cancel it unless you want verification of what we tell you.
BTW, it's cluTch. Maybe that's why your search didn't find anything. Ya think?
Old Mar 22, 2006 | 09:03 AM
cezacho's Avatar
ah you were right it's been covered...thanks.
Mane
Nov 20, 2015 12:16 PM
nowakm99
Oct 9, 2015 07:10 AM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
neoksk
Sep 21, 2015 12:31 PM
