Rear rim size
Old Aug 8, 2003 | 04:28 PM
mazdaexe's Avatar
Rear rim size
From other threads, I heard that the stock rims are 18 x 8.0
Is that for front and rear?
Cuz Im going to get new rims, and they told me that I need 18 x 9.0 for the rear to match the stock offset.
Old Aug 8, 2003 | 04:58 PM
wakeech's Avatar
mostly harmless
Re: Rear rim size
um, what?? as far as i know, the front and rear wheels are identical.
Old Aug 8, 2003 | 07:49 PM
mikeb's Avatar
100% Italian
they are the same
Old Aug 8, 2003 | 11:54 PM
mazdaexe's Avatar
thanx guys, it is the same front and rear.
what do u guys think? should I go for a wider rear?
Or same for front and rear?
Old Aug 9, 2003 | 08:10 AM
RomanoM's Avatar
I Just Can't STOP!
If you have no intention of going to wider than 225 tires, why bother.
You're just adding extra mass.
BTW- a 8" wide wheel will take a 245
Old Aug 9, 2003 | 08:37 PM
MrWigggles's Avatar
My questimate is that the rear wheel well will take a 9.5" at 50mm offset.
I have a set of 9.5" 44mm on my current car and I will see if they fit on my RX-8 when it finally comes in.
But if you are keeping the power stock and don't want to get new tires, than I see no reason to go with wider rims.
-Mr. Wigggles
ladnarf1
Apr 29, 2021 11:53 PM
J2daG1990
Series II Wheels, Tires, Brakes & Suspension
Sep 24, 2015 09:20 AM
Shinka84
Aug 19, 2015 04:55 PM
GK1707
Aug 3, 2015 10:23 PM
