Satellite Radio hookup??
Old Mar 8, 2006 | 10:00 AM
ACRX8's Avatar
I have 2005 RX-8 with the Bose system single CD. I want to install satellite radio.
What is the easiest way to do this. Can I have XM or just Sirius?
Old Mar 8, 2006 | 11:57 AM
New Yorker's Avatar
The easiest way to do it is just buy one of those moveable satellite radio players that you can move between your car and your home. Both Sirius and XM make these; they're not very expensive.
If you want it integrated with the Bose unit in your dash, it has to be Sirius. Mazda sells it as a kit. The "black box" gets installed in your trunk, and a cable has to run from the black box to your dash, which involves removing many trim pieces (in your trunk, door sills, A-pillar) and the in-dash stereo. But when you're finished, it's invisible—and you can hear satellite radio by simply tapping the "SAT" button already on your Bose.
Old Mar 8, 2006 | 12:46 PM
ACRX8's Avatar
Originally Posted by djseto
Or you can get the PIE box for an RCA in. If you have an iPod, you can get the Audiolink which will allow an iPod AND a satellite radio (via mini-phone line input). Either way, don't go FM modulated. Line level is MUCH MUCH MUCH cleaner. PIE box with the RCA adaptor is around $80-90 and the AudioLink is around $120. Do a search on either and you will find many threads. The Audiolink will let you use the steering wheel controls for your iPod.
The PIE box with the RCA adaptor - what do you have to do to install?
RX8mzda
Oct 1, 2015 10:17 PM
Learners_Permit
Sep 27, 2015 07:38 PM
CMRine04
Sep 23, 2015 09:31 AM
XSTARSCREAMX
Sep 20, 2015 01:05 AM
just1jack
Sep 9, 2015 04:45 PM
