New owner - A/C question
Old Mar 7, 2006 | 07:04 PM
nKling's Avatar
Well, I am a new owner, and I wanted to verify something that is going on with my A/C. First off, I have an '05 with a build date of 8/05. Perhaps those of you in cold climates could respond.
Ambient temp: 34 deg F. A/C light off, RECIRC off. The cabin was getting a little warm because the sun was out, so I decided to turn on the air, thinking that the outside air temp was cold enough that it would cool the cabin down little. I had the climate gauge in the very middle (and this was the case with each fan speed), and I notice that the incoming air is very warm, if not close to being hot. I click a notch over.... still warm.
Basically, the incoming air didn't get "cool" until almost all the way over on cold (about 3 or 4 clicks away from the coldest setting). I'm a little worried, because if I can't get cold air when it is 34 degrees outside, I am a little concerned about the summer.
Can anyone else tell me if this is normal or not? Thanks.
Old Mar 7, 2006 | 07:25 PM
scottmhr1's Avatar
You do realize you said the AC light was off, meaning it is not turned on. Your question has nothing to do with AC performance in the summer.
Old Mar 7, 2006 | 07:30 PM
nKling's Avatar
Okay, it actually doesn't matter if the A/C light is on or off, it still blows hot air until about 4 clicks away from max cold.
Basically, I'm concerned that it's 34 degrees outside, I have the temp set to neutral, and you would think that the air would the least bit cool. It's not - the incoming air is hot. That is my concern.
Old Mar 7, 2006 | 08:13 PM
Ericok's Avatar
Rotary Wanker
At 34F outside there's a good chance that the AC won't even turn on because most systems have a safety to prevent the compressor from turning on if it too cold outside. Looked in the owner's manual and it does say that the AC may not come on if the outside temp approaches freezing (32F). The only other thing worth mentioning is that if you've run the car for a while and you turn on the blower (not using AC just the fan) you will get hot air for a while. This car runs hot. The engine has heated up all the ductwork and the outside air will be heated from that heat buildup. After the fan has run for some time, it will eventually cool off.
Old Mar 7, 2006 | 08:43 PM
you must have the temp dial turned into the blue in order to get cool air. about the 9 o'clock position or farther to get cold air. doesnt matter the temp outside. except as stated above where its too cold for the compressor to operate.
Old Mar 7, 2006 | 09:01 PM
nKling's Avatar
Ericok - I hope that the outside temp is the culprit. I will have to wait a few months to find out for sure.
Zoom - I have to turn my dial past 9 o'clock just to get cool air. I just went out and tested it again, and I can hear/feel the heater engage at the 5th click to the right from max cold (still in the blue).
Why is the heater engaged in the blue???
Old Mar 7, 2006 | 09:58 PM
Georgia8er's Avatar
There is no "engagement" of the heater. Your heater works off of coolant from the engine. By turning the temperature dial you open/close a valve in the line going to the heater core and (I think this is how the RX-8 works) move a door that lets air flow from the heater core and or the A/C evaparator.
I have noticed that my temperature dial works more as an "on/off" switch, but most cars I've driven are this way so to me it seems normal.
Old Mar 8, 2006 | 09:21 AM
RotrDoc's Avatar
From: I've shaken off the sands of SouthWest Asia and returned to Houston and Gulfport, MS
It sounds like your system is working normally.
Here's how mine works (in the South, ambient about 50 - 110 degrees):
If you want outside air at ambient (outdoor) temperature, crank the temperature control (red/blue ****) all the way counterclockwise and be sure the mode is set for outside air and the A/C compressor switch off. As others have noted above, the heat starts coming on if the temp **** is set only 3 or 4 notches up (10 o'clock or so). So the useful adjusting range is compressed into about 1/3 of the **** travel. The rest is useless.
Don't worry, there's plenty of cooling there when the weather gets warm and you run the A/C compressor. But you'll need to keep the **** all the way over (7 or 8 o'clock). At least, you will if you have the A/C reprogram that was out a year or so ago.
Old Mar 8, 2006 | 02:33 PM
JonsToy's Avatar
Registered Rep
I pretty much only get cooling on the first three blue notches, and I've had mine a/c in for service already.
Sounds like your's is working normally.
Old Mar 8, 2006 | 03:25 PM
Nubo's Avatar
Lubricious
You're taking the color-coding too literally. Think of it more as a gradual slide from "heater OFF" to "heater FULL".
As Ericok noted, the initial airflow will be warmer because of the heat-soak of the ductwork and heater core. Even if you have it all the way "off", it still heats the outside air somewhat. It's inevitable that the ductwork passes some engine heat to the incoming air. The engine is very low and far back -- that's part of why the car handles so well and is able to seat 4 people in a sportscar.
Old Mar 10, 2006 | 02:16 PM
mikeschaefer's Avatar
I wanna rock! Rock!
That is a very good way to think of it.
People will complain about anything though!
Old Mar 10, 2006 | 07:04 PM
Low Fly'n 8's Avatar
Known fact: The A/C in this car is not very good. It's been discussed in millions (yes millions) of threads.
05TR1CH
Apr 18, 2023 04:56 AM
Skyl3r
Dec 2, 2019 04:51 PM
UHATEIT
Mar 31, 2019 05:31 PM
dancingdan42
Aug 19, 2015 09:29 AM
mazdaverx7
Jul 21, 2015 07:31 PM
