tapping power from rear accessory plug
Old Mar 6, 2006 | 07:35 PM
gnathen's Avatar
i need imput on the setup that i am about to attempt. i want to access the rear accessory plug. tap into it with a line tap using 18 awg wire. run that wire to a terminal strip mounted on my amp rack. run wire from amp and crossover to this terminal strip for 12v turn on. i want the terminal strip for extra options later. Ex. cooling fans for my amp and led lighting for amp and crossover. i would also like to know if on my crossover i can just jump the turn on wire to the +12v connection. i would really like your feed back on this.
Old Mar 6, 2006 | 07:44 PM
Georgia8er's Avatar
One thing you might want to consider is that the rear accessory plug turns off when the key is off. Might be just what you want too.
Old Mar 6, 2006 | 08:13 PM
StealthTL's Avatar
Question Sure....
Sounds like a plan.
It should be OK to power the crossover from there too.
Is there a problem?
S
Audio Concepts ATL
Sep 26, 2021 01:59 PM
uZu
Dec 30, 2015 12:35 PM
akagc
Aug 11, 2015 07:07 PM
Belalnabi
Jul 17, 2015 07:48 PM
AussieGray
Jul 16, 2015 03:58 AM
