Weight of Stock RX8 Parts
Old 01-29-2006, 08:21 PM
Go Texas Longhorns!
brillo's Avatar
I have begun compiling a list of all the weights of the various stock parts of the car
Please PM Zoom44 or Brillo to add any additional information.
Base RX8 / cloth seats / no sunroof / fully fueled - 2960lbs
Hi Power Engine Fully Dressed (Flywheel but no clutch) less Airbox - 267.5lb (per Racing Beat)
Short Block with no attachments per MazMart - 184.0lbs
Stock Wheels (18'') - 21.5lbs
Stock Tires (RE040 18") - 26lbs (some users have reported 28lbs...need to check)
Stock Small Battery - 21.1lbs
Stock Replacement Battery - 37lbs
Lug Nuts - 0.3lbs
Engine Cover - 2.3lbs
Battery Cover - 0.7lbs
Emergency Tire Kit - 4.8lbs
Washer Fluid Tank (full) - 1.43lbs
Car Jack with Case - 6lbs
Bumper Reinforcement - 15.6lbs
Front Seat (power/leather) - 55lbs
Front Seat (cloth/base) - 37.5lbs (including sliders and mounting equipment)
Stock Catback Exhaust - 38.6lbs
Stock Cat & Midpipe - 23.2lbs
Stock Exhaust Manifold (with O2 Sensor) - 17.6lbs
Stock Intake System - 13lbs
Full A/C System - 18lbs
Stock Power Plant Frame - TBD
Stock Aluminum Hood - 15lbs
Stock Front Brake Rotors - 18.5lbs each
Front Calipers and Pads - 13.0lbs each
Stock Rear Brake Rotors - 12.5lbs each
Rear Calipers and Pads - 9lbs each
OE Front Shock Assembly w/ spring - 11.5lbs
OE Rear Shock Assembly w/spring - 12.5lbs
Endlinks front each 7 oz
Front sway bar 6.3lbs
Fog lights 1.2lbs
Oil pan with bolts 4.7lbs
headlight washer with hose 1.75lbs
4 brake dust covers 2.4lbs
Strut Front Bar 4lb
Aftermarket Parts:
Mazda Speed Exhaust - 33lbs
RX8 Store Cat - 11.31lbs
Greddy oil pan with bolts 6 LBS 1 oz
Intercooler piping with BOV no silicone couplings 7 LBS 0 oz
Greddy catch can 1.75lb
Greddy air filter 2 LBS
Interceptor X-EMS 3 LBS
Intercooler 10.6lbs
Turbo header with bracket 20.3lbs
Turbo *Greddy * 12.5lbs
Front racing beat sway bar 9.4lbs
Racing beat endlinks EACH 11 oz
Greddy strut bar Front 4.6lbs
Couplings with metal straps 3 LBS 0 oz
Greddy Front Strut Bar 4.6lbs
Old 01-29-2006, 08:44 PM
BRGREEN8's Avatar
stock aluminum hood is 15 pounds, i weighted it when i replaced it with my CF hood.
Old 01-29-2006, 09:25 PM
Momentum Keeps Me Going
Spin9k's Avatar
New large capacity battery from Mazda 38lbs
Old 02-04-2006, 01:53 AM
stock intake including vdaf, but no air filter. 13lbs.
Old 02-09-2006, 11:36 AM
salituro64's Avatar
My TSB upgraded battery just added an additional 16lbs?
Old 02-09-2006, 06:18 PM
salituro64's Avatar
The question was because I wasn't aware of the difference in size. I saw the original, but I never looked at the new one. Now I'm curious.
Old 02-09-2006, 06:48 PM
drivelinestore.com
lazi's Avatar
i could have sworn that the stock hood was 21lbs or so.
Old 02-09-2006, 07:20 PM
Beodude123's Avatar
Wow, sweet collection going there guys. I bet getting lightweight 17s help a good little bit then huh?
Old 02-10-2006, 07:18 AM
salituro64's Avatar
Originally Posted by TeamRX8
Well somebody confirmed that the weight increased by that much so I'm not sure what you're curious about.
I'm curious as to the size difference of the battery.
Old 02-10-2006, 05:16 PM
THREAD KILLER
Xyntax's Avatar
can I add? Base model 2880 lbs at empty light glow (3 gallons left in the tank).
Old 02-19-2006, 05:20 PM
road warrior
LionZoo's Avatar
Adding 12.9 gallons of fuel to get the curb weight gives just about 2960 pounds, which is what has been reported up top. Is our weight with or without the new heavier battery?
Old 03-09-2006, 10:40 AM
shinronin's Avatar
fyi, tirerack.com's spec sheet on the re040 says the 225/45/18 weighs 28 lbs. not 26.
Old 03-09-2006, 11:04 AM
Go Texas Longhorns!
brillo's Avatar
per Bridgestone's website, they say 26lb, and since they make the tire I thought they would be the best source.
http://www.bridgestonetire.com/tires...r/index_bs.asp
Old 03-09-2006, 11:53 AM
shinronin's Avatar
i see your point, but i'd trust tirerack's data over a manufacturer's tire data. the tirerack's in a position to verify such data and manufacturers often embellish a bit. i guess we need someone to put a re040 on a digital scale.
it might also be a good idea to list the source of the weight data you supply for better transparency.
Old 03-10-2006, 08:23 AM
UnstoppableDrew's Avatar
My RE040's are sitting in garbage bags under my deck waiting for spring (I couldn't afford both the snows AND new wheels for them in one shot). If I remember it I'll weigh one this weekend.
Old 03-11-2006, 06:51 AM
According to my digital bathroom scale (1/2 lb resolution) the RE040s are 27.5 lb. They don't have more the 4k miles on them, so wear shouldn't be an issue.
Old 03-19-2006, 12:26 AM
always preoccupied.
ddub's Avatar
I noticed you didn't have the stock cat weight. Am I right to assume you mean stock cat/midpipe for that?
Anyways, I got 23.4 pounds when I weighed the stock midpipe.
Old 03-24-2006, 11:17 PM
Senor Carnegrande
BaronVonBigmeat's Avatar
Has anyone found out the weight savings for an aluminum radiator? Or is there any.
Old 03-24-2006, 11:52 PM
StealthTL's Avatar
Bigger.....
Don't think there would be a saving from a good aftermarket aluminum rad - the stock is also aluminum, plus the new one would have more tube area, more fins, and hold more fluid.
S
Old 03-26-2006, 08:16 PM
No respecter of malarkey
Received 2,009 Likes on 1,638 Posts
LOL, the entire A/C system from the firewall forward (engine bay area) is only 18 lb. including all the pipes/hoses, condensor, idler pulley assembly, A/C drive pulley, drive belt, and bolts. Mazda didn't leave much there, the pipes/hoses are amazingly light. Probably not worth it except for the most serious efforts, but it's already out now ...
should have the front cloth seat weights soon
I verified the OE intake weight listed, fwiw the air box insulator shield is 3 lbs for those who choose to leave it in place like for the Umnitza intake, it was included in the larger total weight number
edit: deleted a bunch of comments, not really appropriate to have general discussion in this thread
Old 03-26-2006, 08:21 PM
always preoccupied.
ddub's Avatar
Only 18 pounds eh? That's kind of lame. I remember when I removed it on my 2nd gen rx7, so many people were quoting 50 pounds for the AC alone. Well after it was all out I weighed everything and it was about 23 pounds heh. Oh well, the AC system was dead anyways so I wasn't using it.
I figured the rx8 system would be light, and 18 pounds sounds about right. Maybe some day I'll take that plunge, I'm running out of the "simple" things to remove weight. I can live without AC
Old 03-26-2006, 08:23 PM
"Call me Darkman"
DARKMAZ8's Avatar
Do you want cranking power/capacity or light weight?
What do you think of braile batteries? 11-13lbs
Old 03-26-2006, 08:48 PM
"Call me Darkman"
DARKMAZ8's Avatar
why not install it(battery) in the trunk?
I'd be interested to know the weights of these items:
front rebar
airbags
steering wheel
trunk
stock shift ****
full antifreeze container
Old 03-26-2006, 09:13 PM
"Call me Darkman"
DARKMAZ8's Avatar
IMO there's no need for relocating it to the back. This would require longer, heavier cables that then have to be routed all the way up to front connection points. I don't see it being an issue up front given the present plan. It will be located at the front axle centerline down low. Why hassle with a rear mount only to have it sit higher? In fact I'm a bit concerned about getting too much weight off the front end. The majority of weight coming out will impact the front weight balance more than the rear.
None of the stuff you have listed is coming out for me, sorry ...
How much weight have you removed from the front? I know you have the titanium exhaust and I suspect you removed the jack, ect. Having a little more weight in the rear is not all that bad. In fact, it's better for traction imo.
Old 03-26-2006, 09:46 PM
"Call me Darkman"
DARKMAZ8's Avatar
Is this a dedicated auto x car or do you daily drive it also? No point in running duals unless it's for looks.
Quick Reply: Weight of Stock RX8 Parts
