First Problem With My Car!!
Old Aug 4, 2003 | 09:54 PM
bassik277's Avatar
My horn doesnt sound!!!!!!!!!!!!!!!!!!!!!!!
Old Aug 4, 2003 | 09:56 PM
j-apex rx's Avatar
fuse check that first.
Old Aug 4, 2003 | 10:00 PM
CERAMICSEAL's Avatar
bassik, have you done any alterations or mods to your car as yet?
That is a little unusual.
Old Aug 4, 2003 | 10:01 PM
cueball's Avatar
Good thing its still under warrenty.
But check the fuse before you take it to the dealer.
Old Aug 5, 2003 | 01:02 AM
bassik277's Avatar
Thanks a lot guys, its was indeed the fuse which was burnt out. So i swapped it with one of the replacement fuses that come with the car and everything is working fine now. Btw, the owners manual had very easy and detailed intructions where to find the fuses for each component and how to replace them.
Old Aug 5, 2003 | 04:08 AM
BillK's Avatar
Make sure you visit your dealer if not just to get a replacement fuse then to have them check things out as obviously there's no reason you should have blown a fuse and both the check and fuse are warranty issues...
Old Aug 11, 2003 | 10:07 AM
Ron_Jeremy's Avatar
I got the same problem -- taking my car in today ...does this have anything to do with the Shock Sensor being installed?
Has anyone else had this happen as well?
Old Aug 12, 2003 | 12:56 PM
Ron_Jeremy's Avatar
Turns out that BOTH horns were burnt out (sensitive shock sensor set it off one night).. dealer has already replaced on horn (the other is on order)....
Old Aug 12, 2003 | 02:31 PM
neit_jnf's Avatar
I didn't know it has two horns!
Old Aug 13, 2003 | 02:21 PM
Wolfer's Avatar
Car has a horn? I never did hear what it sounds like. I better go test it out. Hmmm only had it for a month now heh.
Old Aug 13, 2003 | 02:58 PM
Puppy1's Avatar
Pure Unadulterated Fun
Tested mine yesterday because of this thread. But I had already heard the horn each time I double clicked the lock button on the FOB.
Skyl3r
Dec 2, 2019 04:51 PM
MarkX
Jul 31, 2015 07:50 AM
netrovers
Jul 20, 2015 03:32 AM
Kangarhew
Jul 18, 2015 08:27 PM
Belalnabi
Jul 17, 2015 07:48 PM
