DIY: Defi controller installed in ashtray.
Old Jan 23, 2006 | 09:12 PM
Jyariten's Avatar
I installed a Defi link display controller and VSD concept controller in an ashtray.
I changed the surface rough finish of a cover of an ashtray for the painting in piano black in D.I.Y.
Attached Thumbnails DIY: Defi controller installed in ashtray.-crw_3674.jpg   DIY: Defi controller installed in ashtray.-crw_3675.jpg   DIY: Defi controller installed in ashtray.-crw_3676.jpg   DIY: Defi controller installed in ashtray.-crw_3690.jpg   DIY: Defi controller installed in ashtray.-crw_3681.jpg
Old Jan 23, 2006 | 09:19 PM
rkostolni's Avatar
Looks great. What paint did you use?
Old Jan 23, 2006 | 10:14 PM
Jyariten's Avatar
HOLTS Spray Paint.
I do polishing in sandpaper (#1500) after having painted it.
I improve it in Compound of ultra-fine particles afterwards.
Old Apr 13, 2006 | 09:10 AM
Alex_'s Avatar
RE Mix
Only one question...where do you take electric cable? i.e. did you connect defi controller to ECU or did you use another cable? Do you have photos or other , I want installa a control unit by my self but I need some image
Thank you
Old Apr 13, 2006 | 09:41 AM
Jyariten's Avatar
Please see this site.
http://www.nippon-seiki.co.jp/defi/car/list.html
Old Apr 14, 2006 | 01:32 AM
Alex_'s Avatar
RE Mix
I know, but for me it's difficoult understand, there are some images that explain everything?
Thank you
Old Apr 15, 2006 | 07:02 AM
takahashi's Avatar
Hey since we have CAN diagnosting system. I think we cannot get a line from the ECU that single out the tachno speed whatever and it has to get it from the CAN slot - under your steering wheel.
http://www.nippon-seiki.co.jp/defi/car/rev.html
Here - plug it in and hook up the wire.
Old Apr 19, 2006 | 05:28 AM
BigOLundh's Avatar
#1 Legend
I am interested in refinishing the ashtray lid to piano black.
Does the lid just pop right off?
Old Apr 19, 2006 | 06:39 AM
Jyariten's Avatar
Yes, remove it. w
Old Jan 22, 2007 | 01:25 PM
mcstin's Avatar
Is there a D.I.Y. for removal of the ashtray/lighter compartment as shown in the 2nd picture? I am trying to remove it, and cut a hole in the piece on bottom left of the picture so I can put my Ipod in there.
Old Jan 22, 2007 | 05:06 PM
chickenwafer's Avatar
Nope
to remove the ashtray:
-unscrew and remove the shift ****, set aside
-reach to the center console panel (where the e-brake is) and reach under the handle and tug up on the panel. One side will pop up, then pull up again and remove and panel. If you have heated seats or a nav system unplug the connectors.
-There are two Phillips head screws holding in the ashtray. Unscrew them and then simply pull the ashtray assembly towards you. It will pop out just like the center console panel did. Unplug the connectors and the ashtray is free.
Pretty easy
Dave
Old Jan 29, 2007 | 10:42 AM
mcstin's Avatar
Thanks for the help. It went just like you said.
Old Apr 22, 2008 | 04:17 AM
BoosTED's Avatar
Jya riten do you have any pictures of the VSD?
yankeepicker
Sep 11, 2015 05:42 PM
Sep 6, 2015 01:04 PM
