Cruising RPM?!
Old Jan 17, 2006 | 03:42 PM
sstricker's Avatar
of course i searched!?
Cruising RPM?!
i searched........
this is not a poor MPG thread.
All I want to know is: at what RPM are you running at say 70-75 MPH on cruise?
I'm running around 4000 RPM is this normal?
Thanks in advance for your positive input!
Old Jan 17, 2006 | 04:04 PM
ezrider55's Avatar
Yes.
Old Jan 17, 2006 | 04:12 PM
Yup, perfectly normal.
In fact, I rarely look at the speed when I'm driving on the freeway...if I look down at see 4,000 rpm, I pretty much know how fast I'm going.
Old Jan 17, 2006 | 04:25 PM
sstricker's Avatar
thanks alot guys! i was just curious due to the fact that this is definately my first rotary and my first manual!! I notice that most other cars, and I know that this car is not just another car, run at around 2000 at cruising speed. thanks for the input
Old Jan 17, 2006 | 04:39 PM
brothervoodoo's Avatar
RainMan is Back
FYI as an aside. Apparenetly you get more MPG is you cruise under 3750rpm, which is right before the first set of fuel injectors open. Something to note if your in a position where you want to ring the MPG for all you can get..
Old Jan 17, 2006 | 04:42 PM
sstricker's Avatar
just checked my mileage today when i filled up... just a hair over 17 with mixed city/hwy..... i can deal with that!
Old Jan 17, 2006 | 04:44 PM
Tirminyl's Avatar
Listen to Zoom44
Wow, that 6th gear isn't being put to good use. I thought 3200rpm @ 70mph was bad.
Old Jan 17, 2006 | 05:19 PM
sstricker:
Yeah, the 4,000 might seem a bit high compared to normal piston engines but you have to keep in mind how different our rotary engines are.
A piston engine would not like cruising at that rpm range but most piston engines have a MUCH lower redline. (5k, maybe 6K)
Don't think of it as 4,000 but where is it in relationship to the redline...you've still got 5,500 rpms to go.
Old Jan 18, 2006 | 07:27 AM
Tirminyl's Avatar
Listen to Zoom44
Yeah but an overdrive gear should provide low rpms for highway driving. 3k would not be bad...even a hair under. Remember, you can always downshift if you need to pass.
Old Jan 18, 2006 | 08:20 AM
Asmoran's Avatar
Look at it this way. 3k rpm cruise with a 5k rpm redline means you're using three fifths of your available rpms to cruise. That's a ratio of 0.6. 4k rpm with a 9k redline is four ninths, or .44.
So comparatively, our cruising revs are lower than those of your normal piston engine.
Old Jan 18, 2006 | 08:42 AM
Tirminyl's Avatar
Listen to Zoom44
Per your math I have a cruise rpm at 3k with a 6500rpm redline. That is .46. Not to get this topic off subject terribly.
Old Jan 25, 2006 | 11:48 PM
xabjw4's Avatar
piston engine cruise
My sister has a new Acura RSX type-S, 2.0 L with a six-speed trans. The redline is 8100 rpm and the 70 mph cruise is at about 3,650 rpm so its nearly the same as the RX-8. smaller displacement needs the gearing to keep the zip in it. I cruise at 68-70 mpg to keep below the 3750 rpm point and stay on the primary injectors, that gets the best gas milage for me on the hwy, about 23 mpg average (all hwy).
Great,
Jeff B.
Old Jan 26, 2006 | 06:33 PM
beachdog's Avatar
Not to turn this into an mpgs thread... I have tested the 3750 rpm myth and have no belief in any validity. I find less than .5mpg difference cruising at 70 or 80. Even ran a full tank without ever shifting past 5th gear just to run the rpms up like cruising at 90 and no effect.
mdl0209
May 23, 2019 05:46 PM
D13
Oct 1, 2015 07:55 AM
tommy26Germany
Sep 29, 2015 10:33 AM
