Can MT oil cooler fit on AT RX8?
Old Jan 11, 2006 | 10:25 PM
Zero_Rotary's Avatar
Double 8
Im planning to upgrade my cooling system, i was wondering if the oil cooler for MT can fit to AT RX8s? I cant seem to find oil cooler thats specifically states for AT. Please help before i purchase any oil coolers. Thanks.
Old Jan 11, 2006 | 11:08 PM
yiksing's Avatar
the giant tastetickles
Now why would Mazda wanna make a different spec oil cooler for the AT?
Old Jan 12, 2006 | 01:56 AM
RX8 Brunei's Avatar
Rotary Lover
From: Brunei: Where Ricers show off their fugly rides
you should get air diversion plate & radiator too IMO.
Old Jan 13, 2006 | 09:02 PM
Double 8
I was checking on some performance radiator, some of them stated only for MT, so im not about oil coolers, theres a mazdaspeed oil cooler selling on the web but mentioned for MT. Just wanna make sure if u guys know anything about it whether theres any difference...etc..
Old Jan 13, 2006 | 09:28 PM
KJ238's Avatar
Air + Fuel + Spark = Boom
HKS makes an oil cooler kit that runs in parallel (ie has its own fuel pump, etc)....
It also had a diversion plate...
Old Jan 14, 2006 | 12:41 AM
RX8 Brunei's Avatar
Rotary Lover
no other way than u make it custom. maybe it's only the fitting issue ..... i don't know why AT don't any of these things for the time being.
Old Jan 15, 2006 | 08:03 AM
09Factor's Avatar
Original Turbo 'd Auto !!
The Mt oil cooler will fit on the At. You will need the right side mounting bracket, the diverter hood, the fittings and hoses that x-fer the oil from the left to the right side. Check w/ Mazmart and see what he has availble.
Now when they say the radiator is only for the Mt it's beacuse the At radiator has the transmission cooler attached to the bottom of the radiator. If you switch out the radiator you will have to plumb in an after market tranny cooler. I doing a DIY on that now just been dragging my heals posting it.
So any after market radiator for the 8 will fit the At, you just have to take care of the tranny cooler.
Old Jan 16, 2006 | 09:31 AM
Double 8
Thanks guys...now maybe im getting another extra oil cooler since i only have one...just worried as the climate here in my country is hot all year!
Old Jan 16, 2006 | 09:51 AM
my10ae's Avatar
Moderator
Post
Originally Posted by 09Factor
Now when they say the radiator is only for the Mt it's beacuse the At radiator has the transmission cooler attached to the bottom of the radiator. .
So that may be the reason why Mazda states the front air dam is not compatible with AT's? Because the tranny cooler is located on the bottom of the radiator, the front aim dam might impede the air flow needed for the tranny cooler. I know the front air dam fits all AT's and MT's, just didn't know why Mazda said it was incompatible.
Old Jan 17, 2006 | 08:29 AM
09Factor's Avatar
You know I never though of that. I still don't understand why that statement is made.
The air dam dosen't block air from the radiator, but maybe just enough from passing the transmission it self. Just a though.
The At cooler itself isn't exposed to air itself. It's in a plastic end cap attached to the bottom of the radiator. The Engine coolant circs around the At cooler thus cooling the At cooler blah blah blah.
Does the Hot engine coolant feed at the top of the radiator or the bottom?
I don't remember the fluid dynamics Heat convetion law
Jesus Martinez
44
May 6, 2025 08:09 AM
foxyRoXy8
Aug 18, 2015 10:26 PM
RXeckless
Aug 16, 2015 12:52 PM
mesaboogie
Aug 7, 2015 10:48 AM
SayDfuse
Aug 3, 2015 10:41 PM
