wheel and tire question
i'll try to make it quick and easy
1. (the big newbie question) disc sugguestion, ill eventually be running some big brakes, so should i need hi disc or low disc wheels, i forgot which one gives you extra caliper clearance
2. offset, im looking for about an inch in the front, and maybe around 3 in the back or something of those proportions. wheel sizing is 19x8.5 front and 19x9.5 rear and my available offests are
Front: 33, 40, 45 hi and 30, 38, and 45 low
Rear: 13, 33, 35, 45 hi 31, 38, and 45 low
3. tire sizing, what is my range of tire widths and according profiles? im thinking 235/35/19 or 245/35/19 and 275/30/19 or 285/30/19. it looks like the 235/35 front and 285/30 rear are going to keep me within 1%
any answers or opinions are appreciated
personally i would go with fronts 30 and rears 31.. but you might need to roll your fender in the rear.. otherwise as long as its above +35 you should be fine in the back....
tire size depends on the look/ride quality and purpose.. i would go with 225/40 and 245/35 but that will give you the drifter look and you will be able to easily clear with those offsets...
codesterb91
Nov 16, 2015 05:57 PM
dweezil22
NE For Sale/Wanted
12
Sep 9, 2015 10:50 AM
Modified Dave
Aug 20, 2015 07:38 PM
ian_rxviii
Aug 10, 2015 02:00 AM
