How to deal with boost creep?
Old Jan 3, 2006 | 12:47 AM
Hybrid-RX8's Avatar
I am currently running the Greddy turbo kit..
I am often enough dealing with boost creep and boost spiking..........so on the safe side I would like to install a external wastegate to help remedy the problem....
What would be the ideal size? I have access to a Tial 46 with a .5 bar spring.
I aware of all the articles stating a smaller wastegate is better matched a smaller turbo running higher boost..and a larger wastegate is matched better with a larger turbo running lower boost.....I have also read that that exhaust gas output on the rotary does change alot of these rules... I notice the RX7 guys are typically running 46mm.
Any input?
Old Jan 3, 2006 | 11:35 AM
rkostolni's Avatar
You could always port out your internal wastegate.
Old Jan 3, 2006 | 11:44 AM
MazsportScott's Avatar
Mazsport.net
What boost controller are you running?
Old Jan 3, 2006 | 12:48 PM
Hybrid-RX8's Avatar
I am using a Profec B Spec II but had problems before the boost controller was placed in. The problems became more significant when my mid pipe was gutted as well.
Hey Scott, I haven't heard back from you in regards to the Modified Mag situation. I look forward to hearing from you soon.
Old Jan 3, 2006 | 01:04 PM
leak?
Old Jan 4, 2006 | 03:00 PM
Hybrid-RX8's Avatar
Checked..no leaks
Old Jan 4, 2006 | 03:19 PM
SSR Engineering's Avatar
Any input?
The reason i'd go with the Tial 46 is because of the components it is made with. It is a nickel based compound for the housing and an inconel valve which can withstand temperatures of 2000+ Farenheit, which makes it ideal for a rotary. Where as the 44 uses a stainless valve/nickel housing and a vband assembly, the 38 uses a stainless valve and housing (and isn't big enough for your application).
05rx8mazda
Nov 28, 2015 09:42 AM
JantzenRX-8
Oct 4, 2015 11:30 PM
FubarI33t
Sep 28, 2015 08:45 PM
Jb4ker96
Sep 27, 2015 10:06 PM
