Need DIY for boost controller
Old Dec 3, 2005 | 12:13 AM
rkostolni's Avatar
I searched for a DIY for a boost controller, but seems unless I missed it, no one has done one. Well I'll try to do a writeup this weekend while installing myne. Wish I had gotten that electrical manual now. Not 100% sure where TPS and Speedometer wires are. I know TPS is at TB and gas pedal, and I read in another post the only speedo wire is at the tranny, but it would be nice to have some exact wire colors, and maybe a pin number at the ecu so I can grab all of those wires at one place.
Old Dec 3, 2005 | 12:36 AM
Moostafa29's Avatar
Storm Trooper
What are you installing? The E-01?
Old Dec 3, 2005 | 11:08 AM
rkostolni's Avatar
I think I'm going to go with the Apexi AVC-R. It supposed to be easier to use than the E-01 and does pretty much all the same stuff.
Old Feb 14, 2006 | 06:40 PM
mikefrombarrie's Avatar
I also need a DIY install for a boost controller, anyone?
Old Feb 14, 2006 | 07:45 PM
Moostafa29's Avatar
Storm Trooper
Which one are you installing?
Old Feb 14, 2006 | 10:03 PM
rkostolni's Avatar
I ment to write one. I even took pictures during my install. I guess I forgot though. I'll see if I still have a copy of the pics.
Old Feb 15, 2006 | 09:58 AM
That would be great! I will probably go for the Greddy Boost controller b-spec II.
Old Feb 15, 2006 | 10:50 AM
epitrochoid's Avatar
Riot Controller
yea, the profec is way easier to install. connect 12v +/-, mount the solenoid, run the lines, connect the solenoid..done. it was way easier than my HKS timer
Old Feb 15, 2006 | 06:23 PM
BigOLundh's Avatar
#1 Legend
I would recommend staying away from the digital profec b spec 2, and stick to their analog units. I have the Profec B Type S, but if you can find the original Profec B that will work as well. Its alot easier to tune and work with.
-hS
Old Feb 15, 2006 | 06:29 PM
Im_DANomite's Avatar
I love GOOOLD
-hS
that's funny you mention staying away from the profec b II. i had the same boost controller installed in my MR2 turbo and the damn thing over boosted and blew out cylinder #3. if it wasn't for the greddy profec b ii...i wouldn't be driving around in my 8. thanks greddy!!!
Old Feb 15, 2006 | 08:14 PM
Thanks for the input guys! I figured the digital unit was better then the type S
glad I asked!
yurcivicsux
192
Sep 12, 2017 10:54 PM
05rx8mazda
Nov 28, 2015 09:42 AM
pjwermuth
Sep 28, 2015 11:36 PM
