Heater not working properly
Old Nov 28, 2005 | 12:08 PM
The Chad's Avatar
Damage Inc.
I was wondering if anyone else had this problem:
I had my HVAC temperature set to the hottest setting and the air flow going through the dash vents only. I went to turn the temp. down one click (about 90% heat) and the car started blowing cold air!!!
It was only about -5 degrees at the time. I had been driving for at least 10 minutes so the engine temperature was normal. I turned it back up to the hottest setting again and it took about 10-15 seconds before the heat came back.
I tried this again on my way to work this morning and the same thing happened - and it was plus 6 at the time?!?!?
I'm taking it in tomorrow to Dave Wood Mazda.
I searched the forum for a similar problem but didn't really find anything along what I experienced.
Let me know if anyone else has noticed this problem.
Old Nov 28, 2005 | 05:01 PM
TLovr's Avatar
I'm a T&A boy
My car only blows hot and even if you turn it to full cold with a/c it's still hot!!, also the reat defrost and the air reserculate dose not work!!
ajax mazda is tryin to fix it and parts are on order, it was sapposed to be done today but they needed more parts so i will have to bring it back for the 4th time:S
tlovr out
Old Nov 28, 2005 | 05:08 PM
TownDrunk's Avatar
I am a meat popcicle
Sorry, but this has to be the funniest thing I've read in a long time... Not that your car being broken is funny... just that someone is complaining that the '8 isn't providing the passenger compartment with enough heat There's a first time for everything I suppose !!
Old Nov 28, 2005 | 09:49 PM
new84me's Avatar
new84me
Unhappy
Quite apart from the comfort issues within the passenger compartment, the lack of heat makes for a dangerous drive for us this time of year because the windows fog in no time at all.......something that is not likely a common issue in the southern U.S.
Old Nov 29, 2005 | 12:09 AM
YT1300's Avatar
Turning and burning
Hmm. The rear defroster I can understand is a bit of a problem, but you really shouldn't be using the recirculator in the winter; the cold, dry air is what you need to heat up to defog the moister air inside the car and clear your windows. Recirculating the warm moist air inside is just going to slow the defogging effect.
Old Nov 29, 2005 | 08:55 AM
Im_DANomite's Avatar
I love GOOOLD
i know for a fact that my 8 loses heat when i'm coming around a corner. i guess the coolant in the heater core is being shifted...that's why i momentarily lose heat.
Old Nov 29, 2005 | 10:26 AM
TLovr's Avatar
I'm a T&A boy
i'm not saying that i use the recirculator or the a/c they just don't work!, but i really want the rear window defroster. i can't lower the temp in the car also!! it's pritty hot in there after 20min. I cant stand it when i know **** dose not work properly even thought i dont use it, i just like to know it will will if i ever need it.
i just went to the dealership and they said that the part they need will take 2-3weeks to get there from japan:S &*#@ing bs.
tlovr out
Old Nov 29, 2005 | 10:49 AM
Shamblerock's Avatar
This car does not have great air or heat. When its really cold outside (-20C or lower) and you are on the highway, you may struggle to keep the car at operating temperature. Not enough heat, unfortunately. A/C in the summer is also not very cold. You have to use recirculate in both cases to get more cold or hot air. Once you start fogging up, turn off the recirculating function.
Its a fact with our car. Its a joke actually, but that's what you own and its not going to change unless Mazda sends out a mass recall and changes the heatercore and other parts. Aparently, the heater core is very small.
Old Dec 1, 2005 | 06:09 AM
The Chad's Avatar
Damage Inc.
Hey guys - just got my car back late yesterday.
Mazda replaced the heating unit - only took a day to get the part.
Seemed to work fine this morning, but now it blows hot until it's halfway into the cold setting.
Oh well - it's better than before.
Old Dec 1, 2005 | 11:48 AM
gerhardj's Avatar
I'm ususally the one blowing hot air and not the car - just thought that was the way our Symbiosis was set up...
Old Dec 8, 2005 | 12:30 AM
RotoRocket's Avatar
Freely Radical
This is a problem for me as well.
It was 11 degrees tonight in Michigan.
I have a M/T Sport Package, so no automatic climate control.
I basically had to leave the heat on the highest, with the fan on the full, to get enough heat.
I'm starting to learn this car's warts. I hope I'm almost done.
Old Dec 8, 2005 | 03:31 PM
Same here. Not enough heat. Does anyone know if they have a revised, larger heater core that could be replaced under warranty?
Old Dec 9, 2005 | 07:24 AM
The Chad's Avatar
Damage Inc.
FYI - My heater was replaced under warranty....not sure if a larger one was put in, but it's working pretty good now.
Old Dec 9, 2005 | 01:54 PM
Chad, which dealer? I'm going to call them and find out.
Thanks in advance.
Old Dec 9, 2005 | 02:39 PM
The Chad's Avatar
Damage Inc.
Thanks in advance.
It was Dave Wood Mazda in Newmarket.
905-895-5747 (toll free 1-888-895-9888)
As soon as I turned the heat down from the hottest setting, it started to blow cold. When I picked it up I didn't get much detail about the problem....just that they replaced the heating unit.
Jesus Martinez
44
May 6, 2025 08:09 AM
escapedan
RX-8 Racing
58
Feb 10, 2020 06:11 PM
Mar 1, 2019 09:00 AM
coolcars44
Nov 29, 2017 05:45 PM
mazdaverx7
Jul 21, 2015 07:31 PM
