RCA Splicing?
Old Nov 26, 2005 | 05:16 PM
gnathen's Avatar
RCA Splicing?
How do i splice RCA cables onto the preamp signal lines coming from the HU just before the Bose amp? The reason i am asking is because the amp i want.. the JL 500/1 only has RCA imputs.
Old Nov 26, 2005 | 06:08 PM
gnathen's Avatar
i know that in order to connect the rca to speaker imputs the positive goes to the center pin and the neg goes to the outer shield. but in the case of our system(Bose) the neg signal is not really neg its just and inverted pos signal. in which case wouldnt that cause problems if directly shorted to the casing of an rca plug? next question can you hook up just the positive side of each rear speaker to the center pin of the rca and not use the inverted signal?
Old Nov 26, 2005 | 08:42 PM
gnathen's Avatar
Ok ive done some research and it looks like the best solution is to add the AudioControl 6xs for my Bose system in the signal path just before the amp. still have a problem. the 6xs also only has RCA imputs, so someone wanna tell me how to get the full range signal(Both the Pos and Inverted signal) to these connections?
F51
Aug 2, 2021 04:07 AM
Jelliott5384
Oct 26, 2016 05:15 PM
Learners_Permit
Sep 27, 2015 07:38 PM
theman
Apr 12, 2005 01:26 AM
skeurton
Apr 22, 2004 02:07 PM
