Racing Beat Catback installed - initial impressions
Old Nov 23, 2005 | 05:18 PM
dmp's Avatar
dmp
RX8 and a Truk....
First off - the product LOOKS first-rate...flawless.
Now for the test drive.
1) the exhaust is 'barely' and I mean 'barely' louder than stock. The exhaust tone is okay
2) the car accelerates as if it's towing a yard of gravel. Engine seems to rev slower...there's no 'sudden pull' like used to be there way back 'yesterday' when I drove it w/ the stock exhaust. Chirp 2nd gear? Forget it. A 'surge' of power just after each shift from 1-2 and 2-3? None whatsoever.
All-in-all, I'll probably sell the exhaust, or have free-er flowing mufflers installed.
There goes $600 down the drain...or at least whatever portion of that I can't recoup.
(shrug).
Old Nov 23, 2005 | 05:30 PM
dmp,
sorry to hear you're not happy with the RB exhaust.
You're one tough cookie to please! First you hate the handling on your car, and now this?
Old Nov 23, 2005 | 05:38 PM
dmp's Avatar
dmp
RX8 and a Truk....
Originally Posted by Jedi54
dmp,
I learned the car's handling. Now it's fine. It was just coming from a Miata to this - the car felt pretty damn heavy...
I'm most taken back by how the car runs - doesn't make sense. I'll give it a week or so and see if it helps.
Old Nov 23, 2005 | 06:34 PM
dmp's Avatar
dmp
RX8 and a Truk....
Okay - secondary impressions...
Just drove the car out for a bit. I dunno what I was feeling before, but the car pulled just fine - infact, uphill, slightly damp a shift into 3rd slid the car sideways a bit - Am very glad I didn't do the 7-second DSC Button Hold technique as I was NOT expecting that.
So - Yeah, it's still too quiet while driving, but I am liking the sound...and I'll figure to get a better judge of any powerband differences next week, as I likely won't drive the car much over the holiday weekend.
Oh - btw, LOOKS amazing
Old Nov 23, 2005 | 06:36 PM
dmp,
Glad its starting to grow on ya.
We need pics...
ZoomZoomH's Avatar
Mulligan User
hey did you ever figure out your REVi intake problem?
i have no more money for modding the 8, so i had to change question to avoid temptation
Old Nov 23, 2005 | 06:39 PM
shinka213's Avatar
Pettit fangurl <3
Hey DMP
I had a similar situation with my Borla....i think an adjustment occurs (like a break-in period)....Im very happy with the sound and performance....
Old Nov 23, 2005 | 06:52 PM
Nemesis8's Avatar
Bigus Rotus
I think a catback is more for 'sound' than RWHP on this car. While it does open up and flow more freely at high RPM's, the catbacks for every day street use are more for a passion on "sound" than "grunt".
Now when you drop in the supercharger one day, dmp, you will like the higher flowing catback even better, but for now does it not sound a little better?
Old Nov 23, 2005 | 06:55 PM
Nemesis8's Avatar
Bigus Rotus
Maybe a midpipe is now in your future...
Old Nov 23, 2005 | 08:10 PM
it's not much louder nor much lighterthan OE, so why bother ... there must be over a dozen other threads on this same subject too
Old Nov 23, 2005 | 08:13 PM
Moostafa29's Avatar
Storm Trooper
Did you remember to reset the computer after installing it?
Old Nov 23, 2005 | 09:37 PM
Raptor2k's Avatar
Club Marbles Member
Hm. $600 for just barely more sound than that of the stock? I think I'm going Greddy.
Old Nov 23, 2005 | 09:48 PM
ECHO1's Avatar
i'm kinda surprised there's no pics the setup you have now is verry similar to what i want, hopefully you see more real/percieved gains for ~1k in mods
Old Nov 23, 2005 | 09:58 PM
dmp's Avatar
dmp
RX8 and a Truk....
I'll put up pics after ppl stop complaining about my mulitiple threads in that forum! :D
Honestly, I think it's HEAVIER Than OEM.
Old Nov 23, 2005 | 10:21 PM
Dmp, it IS heavier then OEM.
Old Nov 23, 2005 | 10:28 PM
shinka213's Avatar
Pettit fangurl <3
at the risk of sounding totally illiterate (lack of rotary intelligence)....how does one reset the computer??
Old Nov 23, 2005 | 10:32 PM
QBallz's Avatar
Unhook the battery for a few minutes.
Old Nov 23, 2005 | 10:35 PM
shinka213's Avatar
Pettit fangurl <3
Is that something that needs to be done after the installation of a catback??
or better yet, if it was installed at the shop, do they normally disconnect the battery?
Old Nov 23, 2005 | 10:36 PM
Moostafa29's Avatar
Storm Trooper
I was either thinking that, or stomping on the brakes 20 times.
Old Nov 23, 2005 | 10:38 PM
shinka213's Avatar
Pettit fangurl <3
how does stomping on the brakes reset the ECU???
curiosity!!!
Old Nov 23, 2005 | 10:56 PM
brothervoodoo's Avatar
RainMan is Back
If you are at certain "flash" level, turn the key to accessory, stomp on the brakes at least 20 times within 8-9 seconds; the oil gauge will sweep left-right back to center, this erases KAM. I would disconnect/reconnect the battery and then do the stomp the brakes procedure if you want to reset your system.
Old Nov 24, 2005 | 02:16 AM
Raptor2k's Avatar
Club Marbles Member
Is resetting the computer a requirement after installing a new catback?
Old Nov 24, 2005 | 04:46 AM
Gerael's Avatar
Rexella's Daddy
try resetting ecu...
but... tone.. in my opinion... the best that i've heard..
power... i don't expect much
Old Nov 24, 2005 | 08:42 AM
RainMan is Back
I don't suspect so, but resetting the ECU erases all the "learned" behavior of the car. Just resetting the ECU alone without installing a MOD is going to give you a perceived boost in power.....
Old Nov 24, 2005 | 10:13 AM
toca's Avatar
i just dont see paying for just the cat back exhaust im going with bb exhaust with cat pipe only way u make any power out tail pipes.
SupraG
Sep 21, 2015 12:09 AM
PTQLam
Aug 16, 2015 05:40 PM
RXeckless
Aug 16, 2015 12:51 PM
SupraG
Aug 3, 2015 10:03 PM
