Evening Interior Light Failure after Install
Old Nov 18, 2005 | 06:17 PM
mcain's Avatar
aka FormerRotor
Question Evening Interior Light Failure after Install
Here's one for you guys:
I recently decided it would be a great idea to install an xm radio and directly wire the power through the cigarette lighter. Thus, I removed the cig lighter area, disconnected the white plastic tabs from the wires, and hardwired the radio through this. Install went well, I replaced all of the removed wiring tabs and turned on the car.
Much to my surprise, the white to red swith now did not occur when I turned on my liights. Also, the sound system illumination is not working at all. I have NO CLUE why this has happenned. Anyone have any ideas?
Old Nov 18, 2005 | 06:56 PM
StealthTL's Avatar
Fuse...
Maybe you grounded the wire(s) and took out a fuse?
S
Old Nov 19, 2005 | 01:06 PM
r0tor's Avatar
i'd go with you popped a fuse
Old Nov 20, 2005 | 09:39 PM
mcain's Avatar
aka FormerRotor
Gracias, gentleman. Sorry about the delayed response. I wasn't thinking when I checked the fuses & forgot that there is an "illumination" fuse in the mix. All is well. Thanks for the help
Old Oct 2, 2006 | 01:42 AM
dasoviet's Avatar
I have a similar problem.
I am powering the carputer i installed through the rear power socket.
I decided to hard wire the cables there are one Black and one green cable.
Does the green cable indicates reverse polarity?
delicious_dallan
Jan 17, 2020 09:17 AM
Skyl3r
Dec 2, 2019 04:51 PM
Crazy.8
Apr 18, 2017 03:17 PM
akagc
Aug 11, 2015 07:07 PM
