How far can you drive on the rx8's donut?
Old Nov 17, 2005 | 09:37 AM
______'s Avatar
I have class, im curious to know if i can get there and back..
Old Nov 17, 2005 | 09:48 AM
khtm's Avatar
I like rusty spoons
I've never even heard of anyone getting a spare for the 8. Most people have the flat tire kit. Putting a spare in the trunk throws off the weight balance.
Old Nov 17, 2005 | 09:49 AM
BlueEyes's Avatar
as few miles as possible.
Old Nov 17, 2005 | 09:52 AM
______'s Avatar
mine was used, came with the spare and the flat tire kit. the wreck broke off my the tire valve so i dunno if i could have used the kit.
Old Nov 17, 2005 | 10:28 AM
khtm's Avatar
I like rusty spoons
I guess you could be the RX-8 club guinnea pig and see how far you can go
Old Nov 17, 2005 | 10:35 AM
______'s Avatar
lol great, ill see if i can make it back or not, i got a pic of the damage besides the tire and wheel, are there picture size limits on this board?
Old Nov 17, 2005 | 10:36 AM
QBallz's Avatar
I believe most donuts are rated 50miles @ <50mph?
Old Nov 17, 2005 | 10:51 AM
Plus, you should only put the donut in the front.
Someone told me that if you put it in the back it could damage the differential or something.... Car thinks tire isn't gripping properly (due to size) so it continues to try and compensate.
Old Nov 17, 2005 | 10:54 AM
______'s Avatar
its in the front, they backed into the front of me
Old Nov 17, 2005 | 11:13 AM
Found it!
Owner's Manaual, page 210, Section 7-5
"With Limited Slip Differential
When using the temporary spare tire on the rear axle, replace it with a standard tire as soon as possible. The size difference between the spare and the standard tire will cause the limited slip differential to malfunction"
Glad yours is in the front because otherwise you'd have to swap the front tire to the back, THEN install the little spare...
Old Nov 18, 2005 | 12:20 AM
Krankor's Avatar
Klingon Grammarian
Wow, thanks! Now I'm triply glad I didn't get the spare!
Old Nov 18, 2005 | 12:48 AM
______'s Avatar
well i made it 30 miles, could tow it because its too low to the ground, so i had to drive it to the shop, 45 all the way. It seemed fine, and on the plus side it seems the tire is gonna be spared, somehow the guys trailer hitch only destroyed the valve lol
Old Nov 18, 2005 | 08:12 AM
cas2themoe's Avatar
PoloRican Rotary
I have one. But I took it out and its sitting in my basement now. Extra weight is not needed! But I bought it just to have it. I hardly ever drive real far from the house, so I'm in pretty good condition. But the tire is most def ugly!
Old Nov 18, 2005 | 11:14 AM
Nubo's Avatar
Lubricious
It's not like it weighs 200 lbs or something.
Yes, I have a spare, so now you've heard of it
RayBarron
Oct 19, 2015 08:08 PM
akagc
Aug 11, 2015 07:07 PM
RX7.9
Jul 20, 2015 12:01 PM
Belalnabi
Jul 17, 2015 07:48 PM
AussieGray
Jul 16, 2015 03:58 AM
