CEL in winter?
Old Nov 11, 2005 | 10:16 PM
KuzuRyuuSen's Avatar
CEL in winter?
hi guys, i just drove my car and i got cell. i didn't do anything to my car, and it just suddenly like that. last time i drove was yesterday at 1.20 am, after that i didn't touch my car until 7.30 pm. yesterday my car was perfectly fine but today the CEL is on. i tried to drive my car and didn't notice any difference, tried to redline it, it's just normal. the only difference for today is the temp is getting low lately. you guys have any guess?
edit: btw this is the first i got cel. oil and engine temp are normal
edit: i did do wot 3-4 times a couple days ago just to test my car performance. do you think that will cause cel? i also tried to reset the ecu by pushing the break pedal until the oil needle swap to the left again.
Old Nov 12, 2005 | 04:51 AM
Go48's Avatar
Are you sure it's the check engine light and not the tire pressure monitoring system light? Colder temps will cause the tire pressure to drop and maybe that's the problem?
Did this happen just after adding fuel? If so, the CEL may be related to a non-sealing gas cap. Check that out and if that is the cause, the CEL will go out after a few start cycles. If not. you'll have to read the error code and act accordingly to correct the problem.
Old Nov 12, 2005 | 06:04 AM
i'm pretty sure that's CEL, the color is orange. i did cross check with my manual. i fill in my tank 3 days ago i think. i'll try to reposition my gas cap. btw how can i read the code other than going to dealer 'cause they're clos on saturday?
Old Nov 12, 2005 | 07:18 AM
Hymeee sCANalyser can pull the codes out.
otherwise .... I have no idea. (thats how I pull mine out b4, but it went away already so I dunno)
Old Nov 12, 2005 | 02:42 PM
Go48's Avatar
Obviously, the dealer can pull the codes as can some auto parts stores. But a CAN-compatible OBDII scanner is required and some auto parts places may not have that kind of scanner. Of course as suggested, the Hymee sCANanalyser (or a Harrison scanner) can pull most of the codes, but you would have to purchase one of those units.
Old Nov 13, 2005 | 02:59 PM
seems like i have to bring my car to dealer. i did tried to recap the gas, and unplug the battery this early morning. it seemed ok at first. but after went driving a little bit, shut off the car, went out again for lunch, shut off. turn on again, went to the school, shut off. went back home, before i shut off my car, the cel is there. so damn weird.
Old Nov 13, 2005 | 03:06 PM
Go48's Avatar
Could be something as simple as a bad gas cap, but you won't know until you determine the error code(s). Best to take it to a dealer if it's still under warranty.
Old Nov 13, 2005 | 03:45 PM
yeah, it's still under warranty. hope it's just a little thing, cause i don't feel any difference other than cel. i just found this somewhat annoying since i'm having exam this tuesday
Old Nov 15, 2005 | 12:03 PM
hi guys, my dealer just told me it's evaporation problem like what you guys guessed. they said they were going to replaced my detector. But I'm kind of doubt about that.
When I checked my car, the cap was loose. I did recap my the gas tank, after that i reset the ecu by disconnecting the battery for couple minutes.
after i reset it, the cel goes away. after few driving it sticked out again. So I was guessing there is no problem with the detector, the problem might be on the cap. what do you guys think?
Old Apr 5, 2006 | 08:29 PM
ITALNRX-8's Avatar
what if the tire pressure comes up when i buy new rims? How do i get rid of it? the sensors wouldn't go on my new rims. that light is driving me nuts.
New_Mazda_Guy
NW RX-8 Forum
Sep 19, 2019 11:20 AM
mdl0209
May 23, 2019 05:46 PM
Rx8 VA Guy
Jun 4, 2016 12:42 AM
RX-8 Racing
20
May 14, 2016 06:25 PM
