Project Mu 4 piston, 345mm
Old Nov 10, 2005 | 08:55 PM
mazdaexe's Avatar
Hi, does anybody know will 18" wheels clear this BBK? I know it depends on offset and design also, but just want to know in general.
Thanx
Old Nov 10, 2005 | 09:41 PM
Endless Rotaries's Avatar
an 18" wheel will clear a 13.5" rotor typically. Just depends on the Caliper. The 4Pot Mu caliper is pretty huge. THis is not the system they use when racing. THis is a show/street system from what I have seen of it. Manf process has changed on this model to make it less expensive and easier to sell.
i'd go towards stoptech if you're going to spend that much on a Japanese system. If going Japanese only buy their race proven stuff or do what I did and GO ENDLESS. Do you know if they are floating or fixed rotors?
Rishie
Old Nov 10, 2005 | 10:42 PM
mazdaexe's Avatar
ok... what size rotors does endless offer? I wanna get something bigger than stock but nothing that needs 19" wheels to fit. I checked endlessusa.com, they only list 323mm, which I think is stock size.
Old Nov 12, 2005 | 02:08 PM
Ya for endless we are not producing a larger rotor than stock. The factory rotor dimensions are plenty large enough for the power and weight of our vehicles. Anything more will just add weight to your unsprung weight.
If you want larger then ED might not be the way to go. I simply did a caliper kit with mine and the difference in pedal modulation and initial response is incredible. not too mention fade resistance, but that can largely be due to pad material.
Rishie
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
mdl0209
May 23, 2019 05:46 PM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
Digitz0070
Oct 7, 2015 12:43 PM
Learners_Permit
Sep 27, 2015 07:38 PM
