V8 in the RX8?
Old Nov 6, 2005 | 11:58 AM
GINTER's Avatar
V8 in the RX8?
Not making too many friends via posting such blasphemy (no rotary in the RX?) - but given that the car is SO light and makes SO little horsepower and that it cost SO much to make SO little extra gain in HP and TQ, I was wondering if it would make sense to drop a small V8, with 400 HP (like from the GTO goat), and maybe add a blower for 500+ HP?
Would it fit?
What would be the down-time to install such a rig?
Stealth-wise, a blown V8 RX-8 could compete with the likes of the new Z06.
Thoughts?
Old Nov 6, 2005 | 12:34 PM
vectorwolf's Avatar
Totally confuzzled...
not sure what would fit in the 8, but I personally know someone with an LS engine in their 2nd-gen RX-7. It M O V E S.
I think the problem might end up being vertical space... The renesis is designed with a very low profile... The taller piston engines would probably not fit under the hood? I could totally be wrong, though...
guitarjunkie28's Avatar
port hacker
would it fit? no
can you MAKE it fit? yes
downtime---- a long time
tranny, driveshaft and diff will have to be changed...halfshafts too probably
much money, much time, but anything's possible.
but before you go that route, why not turbo and ems the 8? you can get 3-400hp out of the renesis with the right setup.
Old Nov 6, 2005 | 12:40 PM
GINTER's Avatar
What would constitute "the right setup?" I've read many threads on this forum, all claiming different numbers with different kits. But I see that most max out at 280 HP, with 300 HP a "wish." 400? I'd be interested in that.. Which kit claims 400 HP?
Old Nov 6, 2005 | 12:51 PM
Moostafa29's Avatar
Storm Trooper
Did the FD have more room in the engine compartment? It seems like the LS1 fits perfectly in there.
Old Nov 6, 2005 | 12:54 PM
epitrochoid's Avatar
Riot Controller
it'd be alot of work, cost alot of money, and we would all hate you.
..but im sure it would be fast. ls1's are real light too, so it still be able to hold its own through the curves.
Frostee's Avatar
I am Goober Wafflelips
wouldnt also adding that much more weight sacrifice a lot of the handling and obviously add a lot of weight to the car?
Old Nov 6, 2005 | 12:59 PM
Moostafa29's Avatar
Storm Trooper
They actually aren't that heavy. You would be putting more weight over the front axles, so the actual balance of the car would be really thrown off. It would be one really fast car though.
Old Nov 6, 2005 | 01:06 PM
Frostee's Avatar
so then you would also probably need to retune the susppension or get a new setup, depending on the actual shifting of weight and balance in order to keep the handling as close to what it currently is, wouldnt you?
sorry, im not all that knowledged in car mods
Old Nov 6, 2005 | 01:21 PM
Moostafa29's Avatar
Storm Trooper
You could probably tune the suspension to help correct some of the shift in weight, but you could never regain that 50/50 balance that we currently have.
Old Nov 6, 2005 | 01:32 PM
GINTER's Avatar
Some cars move certain components to the rear. Like in the Z06, they moved the battery to the back of the car to maintain close to 50/50. Also, they lightened the front parts and replaced steel with aluminum and carbon fiber..
I'd rather go the FI route. Turbo or SC, doesn't matter, as long as the HP reaches 400.
Because of the HP restriction, I might have to go with a G35 coupe.. Their gains are 500+ RWHP with bolt-ons. I need back seats, thus no Z. I sold my 350Z a few months ago.. But the coupe is 40 grand loaded. A Shinka (I love the color) on the other hand, is 30K..
Choices..
Old Nov 6, 2005 | 02:05 PM
Moostafa29's Avatar
Storm Trooper
Choices..
I used to requent the G35/350z forums, and have yet to hear about one that got 500whp from bolt ons. I'm going to have to raise the flag on that one. Please provide some type of proof. But back to topic, even if you found some type of way to ligten the front end of our car, having the engine sit over and infront of the front axle, instead of behind it like it is currently, will have a significant effect on the way the car drives.
Old Nov 6, 2005 | 03:04 PM
port hacker
just get the ptp gt35r kit...
Old Nov 6, 2005 | 03:52 PM
Marietta 8's Avatar
Wink
As the proud owner of both an RX8 and LS1 powered FC I can tell you that the LS1 is extremely cool to drive. Would I want it in my RX8? NO!Does the FC handle like an RX7 and pull like a CAN AM car? YES! Would I do it again? ABSOFUCKINGLUTELY! The FC and FD are great candidates for it because the weight remains nearly identical and sometimes ends up lighter if you can believe that. The 8 engine is lighter than a turbo powertrain from 2nd or 3rd gen plus it sits way back and down in the chassis. An 8 with an LS1 would be unique but not balanced.
FYI: The FC w/LS1 passes Georgia smog, has AC, gets 26 mpg, weighs 2855lbs with a 52/48 weight dist, and..............on street tires runs the 1/4 in the low 12's.
One of the coolest compatisons to my former turbo rotary engined cars is that the overall RWHP is similar. The major difference is that at 2000 rpm the LS1 is making 310 lb/ft tq at the wheels. I don't think Felix Wankel himself could pull that one off.
If you really need that much more power, I suggest you buy a more powerful car.
Old Nov 6, 2005 | 04:37 PM
kw1k's Avatar
buy a used z06
Old Nov 6, 2005 | 04:59 PM
cretinx's Avatar
ok . . . .
www.hinsonsupercars.com
they'll do it for you, told me it would basically cost parts . . . they'd do the labor considering I would give them my car for a few months to work on as a prototype and develop their cradle.
Old Nov 6, 2005 | 05:10 PM
Marietta 8's Avatar
exactly
Old Nov 6, 2005 | 11:04 PM
GINTER's Avatar
I can't find the link right now.. When I do, you can take that flag and shove it you know where. I know for a fact that the 4.3 stroker kit alone gives you 400 HP. With FI you could easily attain 500. True, the stroker kit doesn't qualify in meeting my loosely stated "bolt-on" standards above. Nonetheless, it's achievable. There are streetable 350Z's with 600+ HP and some claim over 1000 (a place in Long Island, NY).
Here's a 350Z with 620+ HP, be it with internals worked on:
http://350zmotoring.com/forums/showthread.php?t=32078
Here, at the bottom of the page, you'll see 619 HP using 93 octane fuel.
http://store.yahoo.com/sgpracing-store/ab03ni35.html
When I find more, I'll let you know.
Thanks everyone for responding. I have a better understanding of trying to fit a v8 into an rx8.
As for the used Z06 comment - I'd have stuck with my 350Z and not sold it, if it had 4 seats. Thus, the Z06 doesn't fit my requirements. The G35c and the RX8 do.
Cheers.
Old Nov 6, 2005 | 11:13 PM
Sapphonica's Avatar
PingMobile
If you're keen on an engine swap, put a modded STi engine in it.
That is one sweeeeeeet powerplant that needs a good home. It is an abuse to have it in such a butt-ugly car as the Impreza.
Old Nov 6, 2005 | 11:22 PM
Moonrover333's Avatar
My Goodness My Guinness
as for the 350/g35 thing there is a Z local who with a greddy setup blew a rod through the block at 9psi and after a $$$$$FULLY BUILT BRAND NEW ENGINE$$$$ can roll easily with a dyno proven 550whp gutted camaro. so as for "bolt on" NO! that engine is glass and has been having some pretty big problems along with the renisis and the 2.4l out of the SRT. now in time after all bugs have been worked out we will see which engine is stronger. but to be completely honest other than being a FAT guy i love my 8 i'm sure the g35 would be much comfortable and it is damn sexy i say keep your car in time people will start to figure this car out as soon as some of these warantees dissapear. if your that desperate for more power drop your car off at PFSupercars with 80k like Eightman i'm sure youll be exstatic sorry for the ramble..... knibb high football ROOOLZZZ
P.S. The STI is a gorgeous car along with the evo so bite your tongue
Old Nov 6, 2005 | 11:25 PM
GINTER's Avatar
I wholeheartedly agree, the STI and the EVO are butt-fugly cars. They're boy-racers. Although the new EVO concept is gorgeous.
However, if I were to put another engine in the RX8, it would not be a 4-banger.
I wonder if you could put a 20b 3-rotor into the 8.. ? I'm just being silly now.. Maybe I'll hook up with the shop linked above and give them my RX8 to play with for a few months, with a new V8.. Or, get a mini-van and be a soccer-mom.
Old Nov 6, 2005 | 11:28 PM
Moostafa29's Avatar
Storm Trooper
Cheers.
This was taken from one of your links:
The net result was 621whp/604trq at 16.5psi of boost pressure and 100 octane fuel.
Summary of engine modifications:
1) Arias 9.0:1 Pistons
2) Pauter ORds
3) JWT Cams/springs
4) Mildly Ported Heads
5) ATS Twin Disc Carbon (finally started slipping at these power levels...time for a triple or a heavier preassure plate)
6) AAM Spec Return Fuel System and Walbro 255
7) 550cc injectors (pushed beyond their limits....need to upgrade to 650cc)
8) 100 octane fuel
9) 16.5psi Boost Pressure
10) Greddy TT kit
11) eManage Ultimate ECU
I would hardly call that "bolt-on". Perhaps we have different definitions, but my flag is staying up.
Old Nov 7, 2005 | 05:11 AM
Ginter you don;t read much about the cars to call them boy racer. Those cars are incredible they are completely functional if you don;t believe me look for the video where the EVO MR FQ400 races the mucialago (spelling?) it stomps it easily now grant it it does have its downfalls but that is also the full race model. All of the EVO's and STI's are incredible and very sexy. i may be buyist because i'm a rally freak but either way they are NOT boy racer at all they are completely functional and will continually be faster than our cars and cost almost the same. as for motor swaps i would gladly drop a 4g63 under the hood of the 8 would take an anus load of work and some form of custom tranny but it would make a **** load of power and be very easy to work on
Old Nov 7, 2005 | 06:32 AM
momo's Avatar
Registered Laker's Fan
Anything is possible, if you can shoehorn a V8 into a Miata chasis. Anyone know how much a LS6 weights? Lets see an LS6 engine with a Z06 kit, should be good for about 450hp.
The problem is in, when you go FI, there is alot you have to worry about just so you don't blow up your engine. Sure FI would be nice, but a N/A V8 with about 450hp would be even better,IMO.
Old Nov 7, 2005 | 09:01 AM
Riot Controller
take any sti/evo off the showroom floor and take it on a rally course, you'll get a great laugh.
THESE ARE NOT RALLY CARS!!!!! a factory sti/evo on a rally course is just the same as a ford taurus on a nascar circuit. manufacturers sponsor race teams to sell cars, and it doesn't do much good to put a car in front of an audience that can't go out and buy something that looks and acts like it. yes, i know the chassis are similar, the engines are smiliar, yeah that's great and all, but the point is both mitsubishi and subaru (and others, but that's all we get in the US) have taken econoboxes and strapped larger wheels, a bigger motor, a turbo, and AWD onto it. yes they're fast, faster than an rx-8 sure....but they're still boy racer cars that mimic things they are not.
