alittle help
Old Nov 3, 2005 | 07:23 AM
kapslock16's Avatar
alittle help
Ok I am trying to connect a LOC this is how I have it. I connect my speaker wire from my rear speak to it. P and V. I then grounf the LOC and connect RCA jacks to amp. Then SUb should play. OK but here is the problem. The Sub does not want to play. Anyone have any sugestions on hooking this up let me knopw please
Old Nov 3, 2005 | 08:19 AM
rkostolni's Avatar
1. Does the aftermarket amplifier have power
2. Are there any warning leds illuminated
3. Use an ohm meter and measure the resistance of the sub.
4. Connect a 9v battery to the sub and make sure it thumps.
5. Make sure the gains on the LOC and the amp are turned up.
Also, I would recommend connecting the LOC before the bose amp instead of after it. This won't make the amp not play, but it should sound better since your not putting the signal through the Bose dsp.
Old Nov 3, 2005 | 08:30 AM
kapslock16's Avatar
alright thx for responding. Here is my problem
My amp turns on and Yes I can hear a thump when I connect the 9v. I am using Scosche SLC4. My amp works the LED power light comes on. I ground my LOC to the battery I connected the left rear speaker and then to input A7 and A8 which are - and +. the I connect to the rca to amp. Still no sound . Also, I have stock radion no bose.
Old Nov 3, 2005 | 09:03 AM
Asmoran's Avatar
I think that's the same LOC I was using in my last car. Kinda transluscent blue plastic? I never grounded mine and it worked fine - maybe try un-grounding it.
Old Jan 21, 2006 | 10:57 AM
BomberNYC's Avatar
i have the SLC4 and one thing you might wanna check out is to make sure gain level on the LOC is up. its set to low when it comes out of the box.
brutalbrad
RX-8 Multimedia/Photo Gallery
48
Jan 31, 2007 02:49 PM
Fuel4theFury
Oct 25, 2006 12:12 AM
kapslock16
Nov 1, 2005 09:28 AM
nosubstitutec4s
General Automotive
29
Sep 29, 2004 09:11 PM
Crashunit
Nov 14, 2003 12:18 AM
