Carbotech pads + centric slotted rotors in the front
Old Oct 31, 2005 | 01:52 PM
DreRX8's Avatar
I replaced my worn down factory front rotors with the the rx7.net centric slotted rotors as well as the carbotech bobcat front pads-- The amount of dust is reduced by ALOT--they are quieter than stock and quieter than the EBC reds I had. As far as stopping power--it feels like they have more bite--but that could just be placebo. They look good together, low dust, and are very quiet yet firm. Highly recommended.
Old Oct 31, 2005 | 02:20 PM
ECHO1's Avatar
nice, i've got some questions:
are your new rotors same size as stock? hows the install? total package cost? are you gonna upgrade your brake lines as well?
i ask b/c those are all mods on my wishlist. glad you like your setup. pics next
Old Oct 31, 2005 | 02:34 PM
DreRX8's Avatar
Well--the rotors are the same as stock--the install I actually had a mechanic do for the rotors--the pads are pretty easy to install yourself though. The Carbotech pads were about $120 IIRC then the rotors were like $160 IIRC for both. Mechanic charged $90 to put on the rotors--pads you can do solo. I got the pads after the rotor install (about 2 weeks later). This pic is with the EBC reds on--note the dirt
Attached Thumbnails Carbotech pads + centric slotted rotors in the front-slotted-rotors.jpg
Old Oct 31, 2005 | 04:49 PM
ECHO1's Avatar
nice...and surprisingly affordable.
Old Oct 31, 2005 | 06:39 PM
PHA RX-8's Avatar
Please keep us up to date on the e-coating which they use on these rotors. I am looking for a no rust solution and I'm torn between this e-coating or a zinc coated rotor. After reading up on those brake pads, I might have to get them.
Old Nov 1, 2005 | 12:06 AM
the only rotor I've ever seen that didn't rust is a new unused one, including zinc coating
Old Nov 1, 2005 | 07:15 AM
alnielsen's Avatar
I would think that any coating is just to cover the surface. On a brake rotor, one or two applications of the brake would remove that coating.
Old Nov 1, 2005 | 09:44 AM
crossbow's Avatar
The coating is primarily for the hub and edge of the brakes. As alnielsen pointed out, any coating on the rotor surface itself will be eliminated in a few miles.
Old Nov 1, 2005 | 09:45 AM
PHA RX-8's Avatar
Actually no. Ford had a coating on the brake surface of the cougar rotors. They made noise, but the rotor never showed signs of rust.
I was really referring to the rotor hub and the rotors fins. The rust that splatters onto the rims seems to come from the rotor fins.
Old Sep 1, 2008 | 08:18 AM
PBlue's Avatar
Dial P for Phantom
How do the centric rotors hold up?
RXFEVER
Sep 11, 2016 02:51 PM
jackslao
Sep 8, 2015 01:50 PM
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
rxwilly8
Sep 2, 2015 02:42 PM
