Rotary engine and flood conditions
Old Jul 25, 2003 | 06:44 AM
AndyPearce's Avatar
As I've never owned a rotary engine and the part of the UK I live in suffered with flash flooding this morning it made me wonder; How does the rotary engine (specifically the RENESIS) behave when driven through deep water (6 inches or more) where there's likely to be a lot of water psuhed into the engine compartment? Is it likely to be the same as any other petrol engine. I know the RENESIS is mounted pretty low down compared to piston engines, could this be a problem in these circumstances?
I'm slightly concerned about getting stuck in a big puddle with my RX8 (when it eventually arrives!)
Old Jul 25, 2003 | 08:40 AM
Magnesium's Avatar
Lurking troll
Sounds like you should have purchased a boat.... j/king
Old Jul 25, 2003 | 10:31 AM
lefuton's Avatar
tyranosaurus rex-8
the renesis, per se, would be about as sensitive to water entering the chamber as any other 10:1 compression motor. you can get a thing called hydrolock...which is really really bad. but in most cases, water really doesn't enter the combustion chambers and it should flow out of the same intake outlet that leaves fall out and other debris.
maybe you can get raising springs? :P or heck a 4wd kit ,)
the car is relatively low to most cars anyways, i would believe you'd have a harder time keeping water from flowing into the muffler before you'd have a problem with water in the intake...this is of course assuming the engine is on. if it isn't, well, uh, maybe build ramps and park it on your roof? j/k
Old Jul 25, 2003 | 10:38 AM
vudoodoodoo's Avatar
I've driven my RX-7 in heavy rain before. Had to go through some good size puddles. No problems.
For your car to injest water, you'd have to go through like 3 ft of water.
Old Jul 25, 2003 | 03:53 PM
AndyPearce's Avatar
Thanks for the responses guys!
1.21 gigawatts!!!
Feb 14, 2019 03:23 AM
Sifu
Aug 30, 2015 10:51 PM
thedragonrotar
Jul 22, 2015 08:46 PM
vssystemluba
Jul 19, 2015 04:16 PM
AussieGray
Jul 16, 2015 03:58 AM
