Slight sqeal when gas is initially applied
Old Oct 9, 2005 | 10:33 AM
SilverrbRX8's Avatar
Silver 05,REVI RAM AIR
Does anyone know why this is happening? when i apply the gas in local slow driving i hear a slight squeal....not quite sute if its a whistle....dont think it is....seems to be like a very very faint brake squel but occurs when the gas is pressed and the car starts to move but goes away once speed increases. any ideas??? ill probably just take it to the dealer ...it has to go in anyway for somethin else.
Old Oct 9, 2005 | 11:18 AM
RotaryManiac's Avatar
1st time rotorhead
Is it a high pitched sound, because i get that too then.
Old Oct 9, 2005 | 01:56 PM
Brice-RX8's Avatar
If you get a high pitch whistle when applying the throttle, that is the sound a rotary makes, kinda like a supercharger, but only quieter.
Old Oct 9, 2005 | 02:03 PM
tiggerlee's Avatar
May Cause Anal Leakage
I've been known to squeal when I push on the gas. :D
Old Oct 9, 2005 | 03:09 PM
MazdaManiac's Avatar
Actually, that is a bit of pre-ignition that happens when accelerate from idle and the ignition timing scheme switches.
There is a lot of initial ignition advance under light throttle (to make it "crisp").
This is "normal" and not an issue. Kind of a "fingernail-on-chalkboard" type of sound for about 1/2 of a second at most.
Old Oct 9, 2005 | 06:15 PM
yes yes very high pitch...not totally unbearable just not sure if it is normal for the time being.....good to hear im not alone nad that its cool. thanks everyone!!!!
92trbolzr
May 18, 2025 09:04 AM
cliffkemp
Dec 24, 2024 10:48 AM
theblinkof
Oct 4, 2023 05:24 PM
D13
Oct 1, 2015 07:55 AM
Zube6115
Sep 30, 2015 12:57 PM
