RX8 Japan Specs Low Power 210HP 5SPM to 250HP High Power
Old Sep 20, 2005 | 11:57 AM
anthger's Avatar
Question RX8 Japan Specs Low Power 210HP 5SPM to 250HP High Power
Hello
i Have an RX8 Japan Specs Low Power 210HP 5 Spead Manual transmision.
I would like to know if there is any way to convert it to the High Power 250HP (6-port)
Old Sep 20, 2005 | 12:36 PM
DreRX8's Avatar
no. It wouldn't be worth the money to do so--cause if I'm not mistaken the 0-60 time of the 4-port 5spd is only what .5 s off that of the 6-port (if that). You'd have to swap trannies and engines. It be more cost efficient to boost it with the Re Amemiya kit or Greddy.
Old Sep 20, 2005 | 12:53 PM
KYLiquid's Avatar
Oil Injection
the only way you could 'convert' it to a 6port would be to get new rotor housing, and intake tract, then ecu....ect ect....would be easyer to just swap the motor. But for the price of the motor swap and all, like dre said, you would be better off just getting a turbo kit for the 4port....give you a lot more 40hp. For around the same cost.
Old Sep 20, 2005 | 12:56 PM
anthger's Avatar
hmm
it seam to be that only with turbo kit this can be done. do you know if the existing turbo kits for RX8 work with the 4-port engine?
Old Sep 20, 2005 | 01:40 PM
ZoomZoomH's Avatar
Mulligan User
I believe RE-Amemiya's kit IS designed for the 4-port engine...
Old Sep 20, 2005 | 02:00 PM
anthger's Avatar
Do you know any online stores or the RE-Amemiyas web page where i can see this turbo kit?
Old Sep 20, 2005 | 05:15 PM
StealthFox's Avatar
nope you're going to have to live in japan and order directly from them or go to their showroom(forgot where it is at the moment)
Old Sep 20, 2005 | 05:47 PM
DreRX8's Avatar
The Greddy kit will work too--there is a Greddy Turboed A/T roaming around. He's getting to 60 in low 6 seconds--so if you have the 5spd then you should better the 6-port times easily.
Old Mar 4, 2009 | 03:25 AM
hakuna matata!
orly?
Old Mar 4, 2009 | 04:15 AM
Flashwing's Avatar
3-wheeler
While not the greatest option, installing a greddy turbo on a 4 port will easily yield 6 port power if not a little more. It would be cheaper to go with a forced induction kit whether turbo or supercharger than doing a motor swap.
Nitrous will also get you close or on top of 6 port power as well.
Old Mar 4, 2009 | 06:38 AM
rotaryPilot's Avatar
Originally Posted by anthger
Hello
I have a European Specs Low Power 192HP 5 speed manual.
We have performed some dynos and the 192HP is a difficult number to see.
How you ever performed a dyno to see if you have 210HP?
Old Mar 4, 2009 | 08:06 AM
foo77's Avatar
4th batch : Apr 03'
here we got only one Euro spec 6 speed which is 184.5hp and Japan spec 6 speed, where the highest only 185.5hp, both were dyno without any mod, bone stock.. i think the hp 210/250 rates just on the paper.. its hard to get 2++hp unless with some mods or FI if i recall one of the members here dynoed his 6 speed ride with Greedy turbo kit 288.1hp
rotorsnsaabs
Aug 26, 2015 08:21 PM
akagc
Aug 11, 2015 07:07 PM
Stubbs
Jul 28, 2015 09:23 PM
Belalnabi
Jul 17, 2015 07:48 PM
AussieGray
Jul 16, 2015 03:58 AM
