Racing seat and state inspection
Old Sep 20, 2005 | 10:22 AM
RotaryZZ's Avatar
Question Racing seat and state inspection
I'm planning to replace my OEM driver's seat with a racing seat on my daily/track car. As we all know, the OEM seat have the side airbag setup. And I was told if I take the seat off, the 'failed airbags' warning light with stay on at the console. My question is will this cause me to fail the state inspection. Btw, I stay in NJ which requires state inspection every two years.
Old Sep 20, 2005 | 10:36 AM
expo1's Avatar
He's as bad as Can
If you bought your car new you will not have to get it inspected in Jersey till its four years old.
Before you spend any money on this read the posts in the search below. I didn’t have an easy time getting a ‘racing seat’ set up in my 8. It takes me less than 15 minutes to swap the stock drivers seat for the Kirkey I now use for track days. Having a similar set up would ovoid any possible inspection problems.
https://www.rx8club.com/showthread.php?t=43784
https://www.rx8club.com/rx-8-discussion-3/install-lower-seat-improve-headroom-63097/
https://www.rx8club.com/series-i-tech-garage-22/removing-lower-seat-cushion-back-seat-70496/
Old Sep 20, 2005 | 10:44 AM
RotaryZZ's Avatar
I realize that too.
I've heard of that too. I'll probably go to a race shop to help me with this issue.
I'm thinking of this all because I'm planning to put in a proper harness for track use. So unless I'm clear on the implications of a racing seat on the state inspection, regardless how remote it is, I will not get the harness in place.
Old Sep 21, 2005 | 09:50 AM
RotaryZZ's Avatar
Don't you have a custom made seat rail installed? Is the stock seat fit well onto the new seat rails too??
Old Sep 21, 2005 | 10:44 AM
expo1's Avatar
He's as bad as Can
The bracket below is custom made by Wedge Eng for the drivers side of the RX-8. It bolts right up to the OEM nuts. The OEM seat belt buckle also attaches to the bracket, still working on getting a 5-point. The Kirkey I use is bolted to that bracket. The threads I posted before have more info.
Duren1
Mountain For Sale/Wanted
Jan 11, 2017 09:07 AM
Ugafan97
SE For Sale/Wanted
Apr 28, 2016 03:35 PM
motohegg
Aug 23, 2015 08:14 AM
akagc
Aug 11, 2015 07:07 PM
Kim Jong Illest
Canada Forum
Jul 23, 2015 03:22 PM
