racing question
Old Aug 31, 2005 | 12:34 AM
rx8gurl's Avatar
racing question
hey wasup guys, i want to ask a stupid question, sorry for my ignorance. I want to know how to smoke the reasr tires. In other words, make the rear tires spin to wamr them up and create smoke, but with the car staying in place. I have seen this done in many drag races but never found out how to do it. I have a stick by the way, thanks
Old Aug 31, 2005 | 12:54 AM
MPG > HP's Avatar
Try window washer fluid (plain water works fine) under the rears on a smooth, flat surface. Be careful no one or nothing is around for you to hit or watching to get you arrested for demonstration of performance! Rev to 5k and dump the clutch. Light hold on brake pedal will keep forward motion down while you floor/pump the throttle to keep rears lit up (heel/toe). To do donuts, turn fronts one way, then soon as the car starts to rotate, go to opposite lock. Don't let the fronts touch the wet pavement or you die. "Hover" left foot over clutch, in case you need to end it, in a hurry. Post a video. LoL.
Old Aug 31, 2005 | 01:08 AM
krangorx8's Avatar
turn off dsc first as its no fun to spin for .0001 seconds and then the rpm's drop.
Old Aug 31, 2005 | 01:12 AM
MPG > HP's Avatar
What he said.
Hold down DSC button for 10 sec after start, until both DSC & TCS are disabled - indicators lit - (always use these in normal operation as they can save your and others lives!).
staticlag's Avatar
The Professor
most important: maual transmission car.
Old Aug 31, 2005 | 01:13 AM
BlueRenesis82's Avatar
Registered Tracker
bwhahahahahahahahahhah
Are you serious?
EDIT
thats not racing, thats being an asshat
Old Aug 31, 2005 | 04:08 AM
jtimbck2's Avatar
I see no direction for this thread to go other than the toilet. Closed.
Sakebomb Garage
Sakebomb Garage
Oct 10, 2018 03:36 PM
sccarally
Gulf RX-8 Forum
Sep 8, 2015 10:34 PM
FERRET
West RX-8 Forum
Jul 22, 2015 02:25 AM
