which other spare will work
Old Jul 25, 2005 | 02:31 PM
raw's Avatar
raw
Does anyone know of what other if any , mazda spare wheels and tires will work on the rx-8?....thanks
Old Jul 27, 2005 | 03:50 PM
dazygirl415's Avatar
I would think that any rim/tire combo would be fine for a spare as long as it's consistent with what the other 3 wheels area (but I'm also not an expert). If you're asking what other Mazda models (i.e. 6, 3...) have rims/wheels that are compatible as a spare for the 8, then I don't know.
Old Jul 28, 2005 | 07:52 AM
KYRX8's Avatar
Any FWD mazda wheels 17" or bigger that is a 5 lug, will fit and work fine for a spare. The 16"s off of the protege 5s (5 lug of course) will fit on the 8s with the smaller front brakes but i dont think they will go over the 320mm front brakes.
Old Jul 28, 2005 | 10:10 AM
KYLiquid's Avatar
Oil Injection
i have put the wheels/tires off my friends Mazdaspeed Protege (17") on my RX8 they clear the bigger brakes fine and dont look too bad. (if that helps). I think the spare tire kit is great, since I usualy 'delete' the spare tire anyhow and just use AAA plus, unlimited free towing.
KYRX8 , are you a member on LexingtonStreets or Louisville streets? Im not an active poster on them anymore (since I movied to FL) but I do read up from time to time.
EDIT : When i said 'spare tire kit' above I mean the bottle of fix-a-flat and the compressor that comes with the car, not the optional spare tire you can get that mounts under the deck lid.
Old Jul 28, 2005 | 10:14 AM
KYRX8's Avatar
im a member of louisvillestreets.com and i own www.lexistreets.com
Old Jul 28, 2005 | 11:17 AM
crisis's Avatar
Just so you are aware the AAA plus member ship allows for free towing up to 100 miles. But you only get 4 towes per year (I know because I've used those 4 towes this year - also why I sold my car '97 mirage). They even send you a letter a month or so after your last tow to tell you they will still come out to help you, but your towes will now incur charges. If there is a better membership level, above plus please let me know.
Kahl
Aug 20, 2015 11:49 PM
RXeckless
Aug 16, 2015 12:52 PM
RXeckless
Aug 16, 2015 12:51 PM
akagc
Aug 11, 2015 07:07 PM
