Why a wide-band oxygen sensor on the RX8??
Old Jun 21, 2005 | 04:57 AM
Rasputin's Avatar
I'm really curious to see if anyone has an idea why our RX8 are fitted with a wide-band lambda sensor considering it apparently (=as far as I have observed with my sCANalyser) only runs in close loop at a stoichiometric AFR. Therefore, a switching HEGO would have done the job as well, if not better.
I have one or two ideas, but I'd like to hear your opinion about it too.
Thanks,
Fabrice
Old Jun 21, 2005 | 06:41 AM
sco's Avatar
sco
My thoughts:
1. Hardware or software limitations with the PCM
2. Flexibility - maybe Mazda thought there may be some need to do some behaviour based on wideband O2 readings (e.g. looking at cat temp + current AFR to determine dump rate of extra fuel for cooling purposes)
Old Jun 21, 2005 | 06:48 AM
timbo's Avatar
rock-->o<--hard place
Useful given it's a car sold to a range of markets, with different emission regs in each (potentially)
Old Jun 21, 2005 | 08:34 AM
Rasputin's Avatar
Originally Posted by sco
My thoughts:
I had similar thoughts, but expressed differently :
1- Initial program assumption might have included some relatively lean burn operation or close loop WOT running but it was canceled for XYZ reason during the program but they had to remain with the same hardware and software (PCM) for cost reasons.
2- Diagnostics : it might be used by the OBD system to monitor the engine management, and maybe to better infer the catalyst temperature.
The Mazda RX8 Training course (borrowed from my dealer) does not give any answer either.
I will also ask the question to some Ford engineers I know.
Fabrice
Old Jun 21, 2005 | 08:50 AM
brillo's Avatar
Go Texas Longhorns!
Emissions were such a issue with the previous cars I'm sure it just helps the PCM better manage the emissions profile and keep the car operating in a clean manor.
Old Jun 21, 2005 | 08:57 AM
Rasputin's Avatar
No that's the point, it doesn't do anything that a narrow bang / switching HEGO could do (better).
F
Old Jun 21, 2005 | 10:18 AM
MazdaManiac's Avatar
Because the A/F target is closer to 12.5:1 in closed loop at some load points.
Old Jun 21, 2005 | 10:29 AM
Rasputin's Avatar
I haven't observed that. At which speed and loads did you see that?
F
Old Jun 21, 2005 | 10:33 AM
4800 RPM to 6250 at 10% to 35% absolute load after 10 to 15 seconds at vehicle speeds over 35 MPH.
Old Jun 21, 2005 | 11:09 AM
Rasputin's Avatar
Thanks MM, I will that as soon as I can.
F
Old Jun 21, 2005 | 11:40 AM
Rasputin's Avatar
Mmmh, can't see it on mine. Here are some data :
- RPM : 5500 to 6000 rpm
- Lambda : slightly rich
- Load_abs : between 20 and 25%
- Fuel System Status : OPEN LOOP!
Don't seem to be running in close loop. Will do some specific runs tomorrow.
Fabrice
Attached Thumbnails Why a wide-band oxygen sensor on the RX8??-afrmazman.jpg
Old Jun 21, 2005 | 11:53 AM
I don't see the open loop flag at all on my car until I hit absolute load numbers above 35%.
Above 35%, it is dependant on vehicle speed.
Old Jun 21, 2005 | 12:01 PM
country differences in pcm programming?
Pelleilee
Sep 29, 2019 10:07 AM
SUKIEE
Oct 9, 2017 09:41 PM
dweezil22
NE For Sale/Wanted
12
Sep 9, 2015 10:50 AM
akagc
Aug 11, 2015 07:07 PM
RX7.9
Jul 20, 2015 12:01 PM
