reverse gear being a b!tch
Old May 30, 2005 | 06:10 PM
LiL BenNy's Avatar
Bubblicious? DEF.
um recently my reverse gear has been really gay. i would put it in and out of R atleast 7 times before it goes into R smoothly.. otherwise i'd end up putting it there and sometimes it will be in and sometimes it wont and when its not my car ends up revving i also tried to put it into 1st then reverse with no luck... any suggestions? is it me? or... the 8... and i remember others having problems with this too... anyone?
Old Jun 1, 2005 | 01:54 PM
LiL BenNy's Avatar
Bubblicious? DEF.
Old Jun 1, 2005 | 02:10 PM
Blue87Sport's Avatar
Rotary only since 1980
You're not alone. Although I don't question my shifter's sexual preferences, I think I know what you mean.
Mine does this on occasion. Press down, shift into reverse, let the clutch out and griiiiind. The shifter appears to be fully in the correct position but it in acuality it is only in part way, thus the grinding. Sometimes I can tell by a barely perceptible difference in the throw but not always. When I suspect its going to happen, I shift back to neutral, release the clutch, re-engage the clutch and shift again.
Mine is sporatic, once a month or so. It may not be the same issue as yours.
Old Jun 1, 2005 | 08:28 PM
according to Motorsport the plastic bushing on the end of the shifter wears and can cause shifting woes, how many miles do you have?
Old Jun 1, 2005 | 09:08 PM
Hung_horse31's Avatar
Maybe this will help
https://www.rx8club.com/showthread.p...verse+grinding
Old Jun 2, 2005 | 01:43 PM
TeamRX8, I have about 19K miles on mine but its been doing this from day one so I don't think its a wear problem.
Old Jun 2, 2005 | 10:31 PM
LiL BenNy's Avatar
Bubblicious? DEF.
[QUOTE]according to Motorsport the plastic bushing on the end of the shifter wears and can cause shifting woes, how many miles do you have?
lol i think i just broke 8,000 lol... 04 built nov 03 i believe.
theblinkof
Oct 4, 2023 05:24 PM
nowakm99
Oct 9, 2015 07:10 AM
Luke.s
Sep 30, 2015 05:57 PM
Zube6115
Sep 30, 2015 12:57 PM
juicemantwon
Sep 26, 2015 12:30 PM
