P & N free revving is ok with us ATs?
Old May 29, 2005 | 10:42 AM
DjRx8's Avatar
Rotary Newbie
I was never sure... (redline ok???)
Old May 29, 2005 | 11:07 AM
Charles R. Hill's Avatar
Owner of BHR
Yes. Just like every other A/T car. The reason rpm's are an issue with AT's is because at high rpm's and high loads the torque converter may "balloon". In a torque converter the one-way clutch is the single part that deals with all of the torque produced by the engine, just like a clutch in a M/T car. This sprag prevents pneumatic pressure back-flow/reversal between the two turbines in the converter. In most factory applications there is no "anti-ballooning" plate protection like in racing converters so the chances for the converter not being able to contain the higher internal pressures will be greater. In park or neutral these concerns do not exist as there is very little load on the converter.
To get a better idea on how torque converters work think of two window fans placed facing each other and one is plugged in(enigine side) and the other is not(tranny side) with the air serving as the trans fluid.
CRH
Old May 30, 2005 | 04:35 AM
DjRx8's Avatar
Rotary Newbie
Alrightttt!
Thanks, Charles, for the clarification.
I'm going out to ZOOM ZOOM my AT 8 right now!!!
Old May 30, 2005 | 09:53 AM
Owner of BHR
Just don't rev it up and the slam it into gear to get the tires to squeal, okay? Neutral slams are bad.
CRH
Old May 30, 2005 | 10:02 AM
09Factor's Avatar
Original Turbo 'd Auto !!
parts start falling off the car if you do....
Old Jun 3, 2005 | 12:20 AM
nzarnow's Avatar
NoahZoom Cop'n'Training
So you can floor it as much as you want and nothing bad will happen? It doesn't put extreme stress on the car like normal v-6s or v-8s?
Old Jun 3, 2005 | 03:49 AM
Vertigo-1's Avatar
Well revving in Park is the only way to do the cold shutdown procedure, so it's obviously ok. Just don't go sticking it in neutral and revving it at a stoplight at somebody that drives a manual...that's just gay.
Old Jun 3, 2005 | 06:04 AM
Owner of BHR
To compare "normal" v-8's and v-6's to the rotary is sacrilege.
CRH
Old Jun 4, 2005 | 01:33 PM
JeRKy 8 Owner's Avatar
Stuck in a love triangle
With the automatic RX-8 I used to have...I performed neutral slams every now and then just for the hell of it. I know it was bad and dangerous but I just wanted to see how much it could help acceleration.
The results were never worth it. The few times where it was executed properly (I'd say maybe 1 out of every 8 attempts) it made take off slightly faster - but nothing much.
Performing a similar manuever on the manual (clutch bomb) cuts down around .5 seconds on your voyage to 60. It's scary how much of a difference it makes,, because without it, to me the manual feels like it makes 60 in the upper 6s/low 7s from a normal start.
Anyway, reving it up and dropping it into D is not worth it. If it made a huge difference I'd say sure - try it once just to feel the added boost - but it just doesn't do enough for you. Plus the only thing you're definitely getting is damage on your transmission.
Jst4fun
Apr 17, 2021 07:43 AM
Jst4fun
Mar 5, 2021 07:16 PM
mdl0209
May 23, 2019 05:46 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
