Lightened Flywheel
Old May 18, 2005 | 07:52 PM
09Factor's Avatar
Original Turbo 'd Auto !!
Lightened Flywheel
What are the pros and cons of lightening the a/t's flywheel be?
I know taking some of the weight out would provide a quicked throtle response, but taking to much weight out would cause slow speed and idle roughness.
Any other info someone can add to this? What am I missing?
Old May 18, 2005 | 08:03 PM
expo1's Avatar
He's as bad as Can
Cars with A/T do not have Flywheels, they have torque converters. Don't expect to find a aftermarket torque converter for the low power version you have. It not cost effective since Mazda will add a better A/T in the future.
http://auto.howstuffworks.com/torque-converter.htm
Old May 18, 2005 | 10:01 PM
09Factor's Avatar
Now since the A/T apparently dosen't have a flywheel, what does the starter spin to start the car then? The Torque converter? I don't think so.
Mazda calls it a drive plate part # 19-021. I applogise if I confused you by calling at a flywheel.
BTW
look at this
http://auto.howstuffworks.com/torque-converter2.htm
Old May 18, 2005 | 10:22 PM
Ajax's Avatar
it has a flywheel.. it's just not the same kind of flywheel as in an MT.
Old May 19, 2005 | 01:59 AM
rotarygod's Avatar
I always called them the ring gear. They are very flimsy light pieces anyways. Just enough mass that the starter has something to grab onto.
Old May 19, 2005 | 09:49 AM
09Factor's Avatar
Well there goes that idea. I knew it wasn't the same as a MT. just throwing the idea out there.
Thanks everyone..
Old Jun 7, 2005 | 10:30 PM
Charles R. Hill's Avatar
Owner of BHR
To better clarify: A/T cars have "flexplates" that have the ring gear that RG mentioned along with the mounting points where the torque converter is bolted on them. The flexplate connects the E-shaft to the T/C and a second purpose of the flexplate is to accomodate any slight mounting misalignments or imperfections that may have occurred during assembly/mating of the engine and transmission. These imperfections are normal. The diameter of the ring gears in the A/T and M/T models are exactly the same. The flexplate is also light enough that it would be a waste to try and lighten it even further.
CRH
Old Jun 8, 2005 | 11:44 AM
spr grn8's Avatar
It's Super Green...
Excellent input Charles! thanks for the simple and specific facts about how my car's
engine and tranny connect. I have always wondered how my A/T was similar and different than the M/T. Save this Thread!
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
xAgyex
Sep 28, 2015 08:54 AM
p8ntman442
Sep 23, 2015 09:18 PM
Anthony Kevin
Sep 7, 2015 07:36 PM
