Help! - Somebody drew on my 8 with permanent marker!
Old May 15, 2005 | 02:00 AM
HolyCow's Avatar
Man, am I ticked! Some a#$hole decided it would be cool to draw on my two month old RX-8 with a black permanent marker. They drew lines down the entire driver's side and on the hood. Anybody have any miracle tips for getting this off??
Attached Thumbnails Help! - Somebody drew on my 8 with permanent marker!-img_0558_t.jpg   Help! - Somebody drew on my 8 with permanent marker!-img_0560_t.jpg
Old May 15, 2005 | 09:06 AM
robe619's Avatar
Fisheyed Fool
Christ! I cannot believe there are individuals that would do that... I feel your anger.
Old May 15, 2005 | 11:01 AM
Lady_Shinka's Avatar
I know it works on a dry erase board but have never tried it on a car. If you get some person that rights in the wrong type of marker on a dry erase board all you do is use a regular marker over top of where the permenant marker was written and then use a dry eraser to erase it off.
This may take it off or may make it worse since I have never tried it before. If you do try it I would put it in one little spot just to test it before doing the whole thing. Hope this helps
Old May 15, 2005 | 11:11 AM
claybar should take it off, follow the standard claybar procedure
you can also try a wax cleaner type product
Goof-Off or similar solvent-based graffitti cleaner
last, there is a solvent called MEK, kind of hard to find anywhere but a paint store, you have to wear rubber gloves and have lots of ventilation, bad stuff, don't press down hard, wipe lightly,
rewax when you're done using any of the above
Old May 15, 2005 | 11:12 AM
MazdaManiac's Avatar
Use "Goof-Off". It will remove it.
3M Adhesive Remover will work, also.
Immediately use a polish and then wax on the affected parts after cleaning with these solvents.
Old May 15, 2005 | 11:35 AM
Speed-ER doc's Avatar
yes, I bite
better than a scratch. let us know how well it came off.
Old May 15, 2005 | 11:50 AM
Air Force RX8's Avatar
Who Cares?
^^exactly what I thought!! If all else fails mineral spirits will work and will not harm the paint.
Old May 15, 2005 | 12:37 PM
Slims8's Avatar
Piston Traitor
Yeah, adhesive remover doesn't work on key marks
Old May 15, 2005 | 03:27 PM
Morgan's Avatar
Lounge Sweetheart
That sucks..k can't belivee people do that kind of crap..i am so sorry
Old May 15, 2005 | 04:47 PM
Huhwha's Avatar
I used paste silver polish and it came right off a dry erase board. FWIW
Old May 16, 2005 | 09:58 AM
vegeta's Avatar
use a red permanent marker and color the black lines to match your car.
hahaha just kidding. Try the "magic eraser," that thing works wonders so I am guessing it may help.
Old May 16, 2005 | 02:13 PM
HolyCow's Avatar
Happened to have some Goof-Off wipes laying around the house, so I took my first crack at the marker lines using them...worked like a charm! I'm back to a nice shiny velocity red without black marker racing stripes.
Now if I could just get my hands on the idiots who marked it up in the first place...then I'd be REALLY happy!
Thanks to all for your concern and suggestions!
Old May 16, 2005 | 03:02 PM
menace1227's Avatar
when you do catch them. tie them up and put racing stripes on them like what they did to your car.
Old May 16, 2005 | 05:13 PM
Flawless's Avatar
I know for a fact lighter fluid will take off that marker (it takes of sharpie). I'm not sure if it will damage the paint though. Might be worth a shot to test it first inside the door jam near where the catch is for the door so it's not visible.
Old May 17, 2005 | 09:34 AM
zipdrive's Avatar
Another dry erase board trick to remove permanent marker is to wipe with a cloth soaked with stale coffee. Might work on the car also.
Old May 19, 2005 | 06:33 AM
draco067's Avatar
Cap'n Limekitten says arr
I can't see any marker lines in those pictures?
Old May 19, 2005 | 08:50 AM
HolyCow's Avatar
Doesn't show in the thumbnails. You need to click on them to get the full sized image.
And thankfully, I already got the marker off with the help of the fellow forum members! :D
Old May 30, 2005 | 08:48 PM
nomopistons's Avatar
nomo RX-8, it's sold
Rubbing alchohol and patience
Old Jun 14, 2005 | 11:10 PM
StphNieuw's Avatar
strong alcohol based perfume should take care of it
Old Jun 15, 2005 | 12:55 AM
nzarnow's Avatar
NoahZoom Cop'n'Training
^^ he said he got if off guys ^^
Post some pics please of after you removed the lines to see how it turned out. Good luck on getting them.
Old Jun 15, 2005 | 04:07 PM
Morgan's Avatar
Lounge Sweetheart
haha, people don't read-they just post...haven't you learned that yet?! oh-well, you're still a newb sorta..you will learn young grasshopper:D
Old Jul 2, 2005 | 12:33 PM
2fast4u's Avatar
Pinnacle Paintwork Cleanse lotion or a clay bar will do it.
Old Jul 16, 2005 | 12:09 AM
StealthFox's Avatar
i cant believe people are still posting sugguestions when 1/4 of the way through you said you got it off >.<
Old Jul 16, 2005 | 12:48 AM
kromix's Avatar
Ti Rx-8 in MiA
What did you use to get it off?? which of the many suggestions worked....?
Warrior777
Jun 24, 2019 04:47 PM
dmengel
Feb 16, 2016 09:47 PM
MatthewRJ
Aug 5, 2015 09:24 AM
He||hammer
Jul 24, 2015 10:56 AM
