Gauge Placement
Old May 3, 2005 | 01:47 PM
cretinx's Avatar
Gauge Placement
Anybody have suggestions where to place some gauges?
I have navigation so I can't place them in the center, and won't the gauges get in the way of the airbags on the pillar if I mount them on the a-pillar?
I was thinking ashtray . . . . any history on this? I vaguely remember one guy installing a head-unit over the ashtray . . . .
Old May 3, 2005 | 01:48 PM
army_rx8's Avatar
X-Sapper
ou can get teh r-majis ashtray guage pod (holds two)....and the a-pillar air bag things has been talked about a lot and pics posted...there are no air backs behind the a-pillar just teh srs symbol is there...trust me i know there isn't i have my guages on the a-pillar.
Old May 3, 2005 | 02:41 PM
jenkins-crew's Avatar
go for the ashtray........
Old May 3, 2005 | 02:43 PM
cretinx's Avatar
Where can I get the ashtray setup?
do you mean R-Magic Army_RX8? Aren't they JDM only?
Old May 3, 2005 | 03:11 PM
Fanman's Avatar
Good luck with R Magic. I had one of those on order through Mazdaparts. They now want you to either buy their gauges with the gauge pod or ship your gauges back there so they can make the hole for them. I ordered it & waited like 6 weeks, and in the meantime they gave me & Matt (thew) the run around. Finally cancelled. If you are interested in it, call Matt & prepare to wait. I've gone back to my A Pillar units. I had ordered the PTP Gauge pod after the R Magic fiasco, but they are back ordered for weeks too (& you have the navi).
Old May 3, 2005 | 03:22 PM
Rasputin's Avatar
I'm intending to fit a nice pair of oil temp and pressure gauges in the ashtray too. The ashtray assembly also features the receptacles for the clips from the plastic gear lever cover. So you can't just take the ashtray away and replace it by a panel of some sort. No, you need to base your integration work on the existing ashtray assy. I'm intending to buy a spare one to work on it and try to make something nice. I think it will still need some flat plate added that will receive my 2 gauges.
I went for the VDO Vision Cockpit gauges. White at day, red at night, like the radio control panel.
Here is a picture of the full kit, including the sandwich plate, the sensors...
Old May 3, 2005 | 03:55 PM
PUR NRG's Avatar
Originally Posted by Rasputin
I'm intending to fit a nice pair of oil temp and pressure gauges in the ashtray too. You need to base your integration work on the existing ashtray assy. I'm intending to buy a spare one to work on it and try to make something nice. I think it will still need some flat plate added that will receive my 2 gauges.
Sounds similar to what I'm doing. I plan to mount a couple gauges inside the ashtray so the cover will still function. It will be a tight fit but should work. This will require extensive rework of the part, some sheet ABS and bondo.
If there's enough interest I might make it a vacform ABS part and sell it for $75. Otherwise it's going to be a custom on-off.
________
Expert insurance
Old May 3, 2005 | 04:19 PM
army_rx8's Avatar
X-Sapper
yes i did..but i wasn't aware there were issues with getting them...i never really looked at it for an option since i had 3 guages to mount :D
Old May 4, 2005 | 12:50 AM
youngpit's Avatar
hope this helps here is where i put mine
Old May 4, 2005 | 08:28 AM
Is that 2nd one in the air vent?
Old May 4, 2005 | 10:22 AM
cretinx's Avatar
they're supersmall . . . hard to see.
please repost?
Old May 4, 2005 | 01:36 PM
8is>enuff's Avatar
Bland
The consensus is that the A-pillar pads are OK.
Check out this thread - https://www.rx8club.com/series-i-interior-audio-electronics-24/gauge-pod-55898/
Old May 4, 2005 | 02:26 PM
youngpit's Avatar
https://www.rx8club.com/showthread.p...1&page=2&pp=15
here is the link 2nd page few down
Old May 4, 2005 | 02:32 PM
Rasputin's Avatar
I don't really like the way they protrude from the ashtray lid, but it seems a very reasonably easy way to do it.
I might consider it if :
- you confirm it's based on the OEM ashtray lid, not a part made from scratch (is it?)
- I can find a way to reduce the protrusion even further
Thanks for the good quality pictures. The gauge integration in the round ventilation outlet is very interesting. Maybe some day for a 3rd gauge...
Old May 4, 2005 | 10:25 PM
fd3s777's Avatar
www.EVO-R.Net
Guys I have 2 type of guage pods for RX-8. These were direct made line up with factory center dash pad. So it will sit direct right on the center dash. Below are some photos. If anyone is interest in them. Please email me. BTW, there are 2 versions. Thanks!
Version 1:
Version 2:
Old May 4, 2005 | 11:05 PM
Fanman's Avatar
I like version 1. But it looks like you will have to cut up the dash. Are those holes 52 mm or 60 mm ? I would be interested.
Old May 4, 2005 | 11:24 PM
fd3s777's Avatar
www.EVO-R.Net
Yes, version 1 require you cut the dash. They are for 52mm guages.
Old May 5, 2005 | 03:17 AM
Rasputin's Avatar
Version 1:
Version 2:
I don't get it. What is the center dash pad? Does it fit on the Sat Nav cover?
Old May 5, 2005 | 03:44 AM
fd3s777's Avatar
www.EVO-R.Net
Smile
Yes it does.
Old May 5, 2005 | 11:03 AM
cretinx's Avatar
hrmmm
the ashtray and center panel mounts look awesome
I can't mount in the center cuz I have nav
I have a-pillar mountings - I never look there - my fave mounting was one gauge on each side of my steering wheel - in my Eclipse
I wonder if you can mount gauges right below the radio instead of in the ashtray, like that guy did with the turbo timer (such a ricer mod!)
Old May 5, 2005 | 11:22 AM
PUR NRG's Avatar
A simple look at that space would tell you there isn't enough room to fit a 52mm circle, let alone a 60mm one.
________
Lovely Wendie99
Old May 5, 2005 | 11:44 AM
RX-8fan01's Avatar
Cretinx i but my boost gauge and AFR on my A-piller they do not have a pod for it so i bought one for a Civic and heated the pod up and molded it with a little fiberglass for my a-piller turned out great i also painted it to match the interior i will post pics later ...
Shane
Old May 5, 2005 | 12:18 PM
Rasputin's Avatar
Of course there is sufficient space down there. Check previous posts about this + pictures...
Old May 5, 2005 | 12:40 PM
PUR NRG's Avatar
Can you provide a link? I haven't seen a picture in this thread (or any other) that shows a 52mm gauge mounted right below the radio instead of in the ashtray.
________
Ninfomana
Old May 5, 2005 | 01:31 PM
Rasputin's Avatar
See the link provided by Youngpit on this same thread!
>> https://www.rx8club.com/showthread.p...61&page=2&pp=15
here is the link 2nd page few down <<
