Tranny Oil change
Old May 3, 2005 | 09:42 AM
FX-RX8's Avatar
I hate FWD cars
Question Tranny Oil change
Should I use Redline MT90 NS or non NS???? We have Limited Slip Diff so the right Oil should be NS but I was told other wise......also Do I have to change the Diff's oil too??? I only have 9000 miles on the car....Im doing the Tranny cuz I did the same with my previous 2002 WRX and it made a big improvement in shifting...no grinding of the gears, etc..
Old May 3, 2005 | 09:49 AM
army_rx8's Avatar
X-Sapper
just put in the redline oil tha tthe tranny askes for, i believe it is gt4 or something nliek that.
there are already a lot of threads abotu tranny and diff oil..talking abotu royal purple and redline. fo rmore indepth answers check them they are very long and loaded with great info. :D
Old May 3, 2005 | 10:05 AM
RotorGeek's Avatar
Still spining
The NS means for cars that do not have limited slip. This is off there site
"75W90
Our most popular gear oil, this is the preferred product in nearly all car and light truck differentials, both conventional and limited-slip. 75W90 is preferred for most racing applications. It contains friction modifier which is recommended for limited-slip units. 75W90 Gear Oil can be used in many transmissions and transaxles "
Old May 3, 2005 | 10:10 AM
RotorGeek's Avatar
Still spining
You could do just the tranny if you want but you might as well do both while you have the car on Jack stands. The diff is easier to do also
Old May 3, 2005 | 10:11 AM
army_rx8's Avatar
X-Sapper
^indeed it is. well unles you are having a shop do it..then it'll cost more.
FX-RX8's Avatar
I hate FWD cars
So I ordered the MT90 Red Line.....That should do it Right.
"75W90
Old May 3, 2005 | 11:01 AM
Rotario's Avatar
Long Member
I'm confused: you state "tranny oil change" in the subject, but then start talking about the differential. Regardless, if you are going with RedLine, use the MT-90 in the tranny, and the 75W-90 in the differential.
Best,
Bill
Old May 3, 2005 | 11:22 AM
RotorGeek's Avatar
Still spining
Yeah if you just want to change the tranny.
Old May 3, 2005 | 12:27 PM
Dark8's Avatar
Ride Naked!
https://www.rx8club.com/showthread.p...light=red+line
Old May 4, 2005 | 07:24 AM
FX-RX8's Avatar
I hate FWD cars
Exclamation
Thanx for the INFO...those pics are very helpfull.....I will change both oils.
Skyl3r
Dec 2, 2019 04:51 PM
BigMikeATL
May 26, 2016 12:31 AM
Zank300
Aug 26, 2015 07:40 PM
akagc
Aug 11, 2015 07:07 PM
RotaryRider
Jul 20, 2015 07:05 AM
