tricking the car for the dyno?
Old Apr 17, 2005 | 10:50 PM
guitarjunkie28's Avatar
port hacker
i already posted this in another section but didnt' get any responses.
so how about we piggy-back the rear speed sensors tot he front ones? that way, the car will think it's moving.
sound ok or did i bump my head?
Old Apr 18, 2005 | 07:03 AM
smrx8's Avatar
I believe thats what canzoomer use to do and worked a little better
Old Apr 18, 2005 | 08:11 AM
TORacing's Avatar
Someone purposed this same idea along time ago, I believe, but I may be wrong, that we decided that the ECU knew which signals came from the front and which can from the rear, ie. the front and the rear have two different signals. I am pretty sure that is what was said, but I may be wrong.
Old Apr 18, 2005 | 11:33 AM
slavearm's Avatar
Boost Junkie
I thought canzoomer was just disconnecting the rear sensors when he dynod. The only thing I have been able to figure out is that you got about 30 seconds once the wheels start spinning before the ecu throws you to crap map. I would appreciate any input as well.
Thanks,
Slavearm
Old May 3, 2005 | 03:45 PM
tuj's Avatar
tuj
I wouldn't be surprised if there was a command that could be sent to the ECU to allow dyno'ing. Its probably part of the WDS interface into the ECU (maybe?).
Old May 4, 2005 | 02:39 AM
port hacker
wouldn't surprise me
Old May 4, 2005 | 11:44 AM
slavearm's Avatar
Boost Junkie
ZIP tie the rear abs sensors (disconnect them first then zip tie them to the cable so it doesnt hit something while you are dynoing)... you still don't have much time, but the crap map doesnt seem to come on as quickly. Woohoo!
Old May 6, 2005 | 01:59 PM
lucidz's Avatar
You're going about this all wrong by trying to trick the car. If you want a better plot, you should be trying to trick the dyno. Like, by say, putting a different car on there.
Old May 6, 2005 | 09:46 PM
port hacker
what a useless post that was.
Old Aug 22, 2005 | 09:06 PM
RXP33D's Avatar
BUMP.
If I was to put it on a dyno, anything i need to do?
Perhaps swtich DSC off completely?
Thats it? DynoDude does the rest?
Old Aug 22, 2005 | 10:35 PM
rkostolni's Avatar
I thought canzoomer concluded a while ago that pushing and holding the DSC completely removed power from the wheel sensors, and so there was no way those sensors could detect the wheels were moving. So there was no need to remove them.
Old Aug 22, 2005 | 10:41 PM
Nemesis8's Avatar
Bigus Rotus
That's what we did, and it worked. It;s the pickup off the coils that is difficult.
Old Aug 22, 2005 | 10:43 PM
TORacing's Avatar
It can't completely remove poer because the speedo takes the average of all four wheels' speed to display a speed.
Skyl3r
Dec 2, 2019 04:51 PM
akagc
Aug 11, 2015 07:07 PM
Peanutbuttertruffle
Jul 24, 2015 07:49 AM
Bamaham
Jul 23, 2015 08:08 AM
AussieGray
Jul 16, 2015 03:58 AM
