HP/Torque curve super-imposed
Old Sep 5, 2002 | 05:26 PM
Grimace's Avatar
Certifiable car nut
Warning! Bored engineer at work!
I super-imposed the HP/Torque curves. The torque curve is from http://media.mazda.ch. The horsepower curve is from calculation.
This isn't meant to take anything away from Spanish or Stan, but I prefer seeing the curves on 1 graph.
Old Sep 5, 2002 | 05:36 PM
wakeech's Avatar
mostly harmless
wow... pretty.
thanks grims!! you're an engineer??
oh, btw!! i'm stoked that the torque is so high at 1k RPM!! wow... it's 1.3L friends, 1.3 L... wow.
Old Sep 5, 2002 | 06:44 PM
i know what you mean wakeech! 1.3L! every time i tell someone new that it is only 1.3L they think i'm joking. they won't believe me until i show them the specs from mazda:D
Old Sep 5, 2002 | 06:45 PM
Quick_lude's Avatar
Love to rev!
These are flywheel numbers right? Love that flat torque curve..
Old Sep 5, 2002 | 07:46 PM
Grimace's Avatar
Certifiable car nut
Yeah, those are flywheel numbers (at least I'm 99.9% sure they are, it doesn't specifically mention whether they are or not on the site I quoted above).
Yep, I'm an engineer (mechanical). Just graduated.
Old Sep 5, 2002 | 09:38 PM
stan11003's Avatar
Don't Worry
Keep hacking dude, your next assignment make us a 3d model of the interior!! Just kiding very nice graph
Old Sep 6, 2002 | 10:35 AM
Sputnik's Avatar
Couldja redo it so that the HP and torque numbers are on the same scale?
---jps
Old Sep 6, 2002 | 01:22 PM
babylou's Avatar
Oops
Power (hp) = Torque (lb-ft) X Speed (rpm) / 5252. Therefore the power and torque curves must intersect at 5252 rpm. What's up wtih this curve?
Well now I see what's up with the curve. The power and torque scales are different so the intersection point is moot.:o
Old Sep 6, 2002 | 03:10 PM
PatrickB's Avatar
FAQMeister
Okay, I've attached one I made with power and torque on the same scale.
Old Sep 7, 2002 | 01:35 PM
veloceracing's Avatar
Moderatin this biznatch
very cool
that right there is what will beat an S2K, pull in every gear...although not that much.
Old Sep 8, 2002 | 04:49 PM
Sputnik's Avatar
Re: Oops
Originally posted by babylou
...Well now I see what's up with the curve. The power and torque scales are different so the intersection point is moot.:o
Yeah. I normally like to see them at the same scale, so that I can compare them to others a little easier. But that's a personal thing...
Thanks PatrickB!
---jps
Old Jun 21, 2004 | 05:18 AM
IKnowNot'ing's Avatar
Re: HP/Torque curve super-imposed
I just had a look at the torque / power curves on that swiss website and something is definitely wrong with them.
Indeed, if you superimpose them, on the complete RPM range, the 'Hi Power' power curve is always higher than the 'Std Power' curve.
This cannot be right as, if one superimposes the torque curves, it clearly shows that, in some points in the RPM range, they cut each other. At these points, the power rating should be equal for both engine versions (since P=TxN).
So I know the power curves are wrong. Can I therefore trust the torque curves ?
Old Jun 21, 2004 | 05:41 AM
RobDickinson's Avatar
Is the data from mazda media .ch?
If so why should we believe it. That graph is plotting almost 250bhp, even mazda dont say that anymore apart from .jp
Old Jun 21, 2004 | 06:37 AM
Yes it comes from media.ch.
No it says 170 kW (231ps).
Does anyone has a reliable source for actual flywheel (ISO 1585)torque curve for the std power and high power Renesis? I need it to correct and verify a computer model (built on MS Excell) that I'm starting to work on in order to check different ways to improve WOT performances.
Old Jun 21, 2004 | 07:18 AM
BasenjiGuy's Avatar
Not to be a party pooper, but, which PCM flash are these data derived from?
Old Jun 21, 2004 | 08:03 AM
>>>>>>>>>>> This is a joke, right?
Old Jun 21, 2004 | 08:04 AM
8_is_enuf's Avatar
You guys laugh.. But that is the car in stock form with the new "N" flash.
Old Jun 21, 2004 | 09:54 AM
wakeech's Avatar
mostly harmless
...just so everyone understands: no it isn't.
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
superROB23
Sep 4, 2015 01:22 AM
megaman
Aug 14, 2015 08:41 AM
blkswan
Jul 30, 2015 10:55 AM
Red Ryno
Jul 24, 2015 09:06 PM
