Moon roof/sun roof?
Old Mar 24, 2005 | 08:28 PM
glassetcher's Avatar
'04 MT RX8/71 351C Mach1
Question Moon roof/sun roof?
I'm starting to look at RX8s. I've seen references to both a moon roof and a sun roof, but haven't seen any detailed description anywhere. Are these two different options? Can someone please describe?
Old Mar 24, 2005 | 08:31 PM
Rhawb's Avatar
Has the whole shit.
They're referring to the same thing. Touring and Grand Touring packages get what should be called a moonroof (I think, correct me if I'm wrong). It's a tinted glass roof with a slide to cover it up when it's too sunny or parked. Slide open and tilt up features abound.
Old Mar 24, 2005 | 08:36 PM
No More Oldsmobiles's Avatar
Custom User Title:
Rhawb's right that it's just one thing on the RX-8. On the RX-8, the glass slides up over the roof.
My Mazda salesman told me that they call it a moonroof because it does not slide into the roof but over it.
Then I was looking at an Accord with a moonroof that slid inside the roof. The salesman there told me they call it a moonroof because it also has tilt features.
Old Mar 24, 2005 | 08:40 PM
Rhawb's Avatar
Has the whole shit.
I think moonroofs are glass and sunroofs are metal, again, I could be wrong. Seems like the definition varies wildly, though I don't think I've seen a production car with anything but a moonroof (as indicated by the sticker) and I've also never seen a production car with a sliding metal roof (sunroof by what I've been told) so this seems consistent with what I've been told...Er, I hope I'm making sense. I've been doing school work all night and I'm a bit whupped. :o
Old Mar 24, 2005 | 09:01 PM
Thanks for the quick response.
So, as I understand, there is glass panel in the roof that will just tip up for some small fresh air venting, or will slide back over the roof for full open air. There is also a sliding panel inside the cabin, manual I assume, that closes under the glass panel to keep the sun out if you want. Sounds just like the unit in my wife's 93 Camry (except the glass slides into the roof, not up and over it)
Does that about sum it up?
Custom User Title:
Makes sense.
Bottom line is that these terms have been used and misused interchangeably. So whatever car you look at, you have to see exactly what that roof does.
Spring's comin'. Time for a moonroof tan.
Old Mar 24, 2005 | 09:05 PM
Rhawb's Avatar
Has the whole shit.
Yup, you've got it right on.
Haha, no matter how much I try and get the moonroof tan, I always just end up with a really horrible trucker tan. Left arm's all crispy and dark from the sleeve down and the right arm is all pasty and white. Oh well, maybe I'll actually go to the beach or something, seeing as I live in FL...I never actually do though.
Old Mar 25, 2005 | 01:26 AM
socalightning's Avatar
This is how I understand it...
Moonroof = sliding transparent glass panel
Sunroof = sliding opaque panel
I remember my friends VW had the sliding metal roof panel (sunroof) with a hand crank.
Old Mar 25, 2005 | 01:34 AM
Mr. Ed's rx-8's Avatar
no more 8
my sister lives in sarasota...
her husband is a cop
Old Mar 25, 2005 | 06:07 AM
draco067's Avatar
Cap'n Limekitten says arr
Until 2 days ago I would have said the same, until I was in a friend's 2nd gen 325is, and it had a red-painted metal sunroof
Old Mar 25, 2005 | 07:12 AM
khoney's Avatar
FX8TED on my RX-8
Then I guess you've never seen a 2nd gen RX-7 with the sunroof option.
That's what I used to drive - I prefer the moonroof of the RX-8, though.
Old Mar 25, 2005 | 07:22 AM
StewC625's Avatar
Insanely Yellow
Interchangeable names for a device that opens a hole in the roof.
Supposedly in marketing parlance a "moonroof" is one that's made of glass rather than metal ... whatever.
I thought a moonroof was one that was big enough to hang your *** out of ...
Old Mar 25, 2005 | 03:20 PM
Custom User Title:
FYI: I just used google's dictionary feature, answers.com. When I typed in "moonroof," it came back with an entry for "sunroof"!
sun·roof (sŭn'rūf', -rʊf')
n.
A roof on a motor vehicle, such as an automobile, having a panel that can be slid back or raised.
Old Mar 25, 2005 | 06:26 PM
dwynne's Avatar
Gearhead Geek
That is my understanding as well. Had an 83 Rabbit GTI with manual, metal sunroof.
The OEM advantage VS those cheap "cut a hole in your car" items eveyone use to get is the sliding panel to block the sun. That and power, fit, and finish :D
Dennis
Old Mar 25, 2005 | 09:34 PM
Smile
Thank you all for your replies.
Before having actually seen the RX8 today (more later) I was worried this was some inferior example of an electronically moving sun roof (ie. a hole in the roof that lets in air, sun, and rain (if you're not paying attention, or have left it open in the driveway while you are taking a nap)
What I saw on the test drive today looked perfectly reasonable, if not a bit small (alhough this is perfectly reasonable because of the curvature of the roof)
Thanks again!
Warrior777
Jun 24, 2019 04:47 PM
RX-8 Racing
20
May 14, 2016 06:25 PM
p8ntman442
Sep 23, 2015 09:18 PM
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
