Keep your rotors carbon free......
Old Mar 19, 2005 | 10:38 PM
StealthTL's Avatar
Exclamation Keep your rotors carbon free......
Cheap gas, with inadequate additives, can build up deposits on your rotors.....
There is no doubt that there is not enough dispersant additive in regular gas, the minimum that the EPA mandates has declined 50% recently, not enough to keep injectors, valves and piston tops clean. (and DEFINITELY not enough to keep the carbon off rotor faces!)
It is no secret which gas companies make the 'good stuff', the government keeps a list - these companies have agreed to sell only 'Top Tier' gas at all their outlets.
Chevron
Entec
Conoco
Phillips
QuikTrip
76
Shell
The good guys....
Sad to say, they are the ONLY ones you can rely on for adequate protection.
If you read the test procedures, you will notice that the regular gas with no additives will plug injectors like crazy, and build up a heavy weight of crap on the hot engine parts.
"Hear me now, and believe me later", I make gasoline for one of the companies on that list, at the most modern refinery in North America, and we run test engines 24/7 to check the quality.....fuel your '8' with gas that has adequate deposit protection - please!
S
Old Mar 19, 2005 | 10:52 PM
Student Driver
Hey StealthTL:
Thanks for the info.
What would you suggest for an additive if none of the above mentioned fuels are available in my area?
Old Mar 19, 2005 | 10:54 PM
Cam's Avatar
Cam
this space for rent
Damn the gas prices man, Shell V Power is all I use.
Actually, my car sounds better when running the V Power instead of the mid grade.
Funny you posted this. I was just telling my girlfriend about this subject earlier.
Old Mar 19, 2005 | 11:14 PM
StealthTL's Avatar
If there is no T.T. gas in your area, that 'Techron' additive that Chevron sells is proven stuff, and available at PepBoys/Autozones.
Member TRZ750 posted about a Yamaha additive his company makes, called 'Ring Free' - I don't know it, haven't used it, but he has good results with big outboard motors staying deposit-free.
S
Old Mar 22, 2005 | 02:39 AM
Vertigo-1's Avatar
Doesn't doing redline runs every now and then clear out the carbon deposits as well?
Old Mar 22, 2005 | 03:16 AM
poorman's Avatar
Ah man....
and Costco gas was so cheap...
I guess its Shell and Chevron time...
Old Mar 22, 2005 | 03:19 AM
StealthTL's Avatar
Redlining......
Sure, redlining is beneficial, but it does little for your injectors.
S
Old Mar 22, 2005 | 03:47 AM
cas2themoe's Avatar
PoloRican Rotary
Guess I'll be using Shell from now on....................
jamespond24
Dec 1, 2015 11:11 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
pjwermuth
Sep 28, 2015 11:36 PM
GK1707
Sep 27, 2015 07:33 PM
