Before Buying New Wheels/rims....
Old Jun 10, 2003 | 02:32 PM
ibfubar2000's Avatar
ZOOM ZOOM
i have heard different stories regarding the rims/wheels of the rx8. the rx8 wheels have rf sensors in/on them for tire pressure radings and suspension (like the corvette). i do not know if all rx8 have them or just special pakages (gt or tr) but if you buy rims without the rf sensor it will screw up your reading. so yuo might want to check with your dealer BEFORE buying new wheels/rims/tires to see if they are compatable. again this is just rumors ive heard i can not confirm any of this until the car gets here and we can look at one for sure. if anybody else knows about this please post.....
Old Jun 10, 2003 | 03:05 PM
brothervoodoo's Avatar
RainMan is Back
to add more fuel to the fire... here is a related post:
http://www.rx8forum.com/showthread.p...ghlight=sensor
Old Jun 10, 2003 | 03:54 PM
tpryor's Avatar
Re: Before Buying New Wheels/rims....
They are mounted inside the rim and can be swapped from rim to rim, or they are the indirect type that reads from the antilock sensor (nothing inside the wheel at all). Some care has to be taken when mounting a tire (get a reputable shop), but otherwise it's no real issue.
More information at:
http://www.tirerack.com/tires/tirete...essuremoni.htm
Old Jun 10, 2003 | 04:30 PM
Superfan's Avatar
Member
Eastmoon San, Did you swap the sensors to the new rims?
Old Jun 10, 2003 | 08:46 PM
babylou's Avatar
Since Mazda claims the system is RF it uses sensors mounted to the wheels. I have seen these and they are simply mounted with a strap around the wheel. Like a big hose clamp. I bet there are aftermarket straps available.
Old Jun 10, 2003 | 09:30 PM
IGOZMZM's Avatar
Zoom Zoom Member
It has been said many times before that the RX-8 will be using the indirect type of sensor. This type uses the Antilock braking sensors to sense the rotational speed of each wheel. Changing your rims/wheels will be just fine. (even to different sizes, because it's the speed of rotation compared to the other wheels, not compared to a norm.)
Old Jun 10, 2003 | 10:22 PM
eccles's Avatar
Prodigal Wankler
It may have been said, but it was speculation, and incorrect. According to Mazda's own Product Comparison Guide:
Tire pressure monitoring system
• Uses a radio frequency to monitor wheel-mounted tire pressure sensors, activating a warning light in the instrument panel if the tire pressure is too low
According to the Tire Rack page somebody cited earlier, most OEM RF systems use a sensor that's integrated into the valve stem assembly, rather than strapped to the wheel with a band. That being the case, there's a slight possibility that the unit may not fit particular aftermarket rims, depending on the design in the proximity of the valve stem hole.
Old Jun 11, 2003 | 03:00 AM
Efini 8's Avatar
no pistons!
good thing I am getting mine custom forged!
Old Jun 11, 2003 | 03:55 AM
RobDickinson's Avatar
I think I remember East Moon saying the J-spec and euro cars arnt getting tyre pressure sensors.
This is only a US thing because it'll soon be law in US.
Old Jun 11, 2003 | 05:19 AM
EAST MOON's Avatar
thanks RobDickinson Your memory is right.
I already wrote that.
My Japanese spec RX-8 is not have tire pressure sensor, from the first.
EAST MOON
Old Jun 12, 2003 | 12:05 PM
Haze's Avatar
Just out of curiosity, why does the government think that it knows how to build cars? Most of the folks that we vote into congress wouldn't know a spark plug if someone threw one at them . . . not that I would do that. I'm just tired of buying legally required equipment that I have been driving without for most of my life, and have never felt the lack of. Side impact protection, OK I see the reason for that, but I have had catastrophic tire failure, and it was never that big a deal. I want this system like an extra hole in the head, or for instance daytime running lights, which were also legally required for a short time until people forced congress to unrequire them.
Sorry for the rant -
H
Digitz0070
55
Jul 25, 2017 08:40 PM
JCTaylor
Sep 30, 2015 07:31 PM
Quiggs321
Sep 30, 2015 05:34 PM
drlubell
Sep 26, 2015 11:58 PM
