Installing High Power APV motor for the air intake system
Old Feb 24, 2005 | 08:56 AM
yd37's Avatar
Hello,
I'm trying to reinstall the high power apv motor (part number n3h6 13 b70) on the variable air intake system. My question has to do with indexing the teeth on the gear. Do I want the gear on the air intake system to be positioned in such a way to get the optimal power at high rpm?
Thank you
Old Feb 24, 2005 | 04:42 PM
Mr M's Avatar
Evolution of REvolution
Position it so the valve is roughly closed at rest.
The timing of the gears is not critical, the motor is switched on or off for a set time, not a set distance.
jay_tibo
22
Sep 13, 2016 08:10 PM
RXeckless
Aug 16, 2015 12:52 PM
Mr.Durden
Aug 12, 2015 02:21 PM
ripigs
Aug 2, 2015 10:44 PM
AussieGray
Jul 16, 2015 03:58 AM
