Japan Flash?
Old Feb 23, 2005 | 02:50 PM
epitrochoid's Avatar
Riot Controller
i dont think the japanese flash will even load onto a non-JDM ecu. but even then, the code is well encrypted (anyone put it on a logic analyzer?) and loading it onto the ecu requires the mazda tool...you've have to know some brass to get that done.
Old Feb 23, 2005 | 03:53 PM
Mr M's Avatar
Evolution of REvolution
Buy an aftermarket PCM or piggyback.
You can not update PCMs programs like a PC program, it is just not that simple.
Old Feb 23, 2005 | 05:10 PM
RX8_Ownz's Avatar
What about just swapping to JDM ECU?
Old Feb 23, 2005 | 05:16 PM
ddub's Avatar
always preoccupied.
Well then you run into the problems where the Japanese versions of the rx8 have a different setup, some emissions equipment not present, etc., where we US models still have all that stuff. Without the ECU to control them they probably wont do anything.
Now if you completely removed emissions and swapped harnesses I don't see why that wont work, but you'd have to do a fair amount of swapping for things.
Old Feb 23, 2005 | 05:23 PM
Mazmart's Avatar
Are the Japanese cars actually getting higher numbers? I don't believe I've seen anything to document that.
Old Feb 23, 2005 | 06:55 PM
ddub's Avatar
always preoccupied.
No idea, I just got my rx8 yesterday
Old Feb 25, 2005 | 02:22 PM
Racing Beat has the capability now to "flash" the pcm with customized maps
Old Feb 25, 2005 | 02:34 PM
DARKMAZ8's Avatar
"Call me Darkman"
I believe that all u would have to do to run the j-spec ecu is block off the egr, and plug the ecu in......u might want to disable the j-spec speed governer tho .....
are there any japan 8 dynos?
Old Feb 25, 2005 | 02:55 PM
rx8wannahave's Avatar
Follower of CHRIST!!!!!!!
Who, what...when...who, what....what when...who?
RB flashing the ECU (why do you call it pcm?) of the RX8? Any more news about that?
Old Feb 26, 2005 | 11:53 AM
CERAMICSEAL's Avatar
Powertrain Control Module. It's the terminology used by most manufacturers today.
Old Feb 26, 2005 | 04:32 PM
truemagellen's Avatar
Attracts tree branches
dang I thought this was going to be pics of Japanese woman :p
as everyone says it wont work...but even if you swapped everything you'd have problems...CEL CEL CEL and more CELs...it wouldn't be worth it
just work at Racing Beat
RevMeHarder
Jun 1, 2026 02:30 PM
CARBONRX-8
Oct 5, 2015 03:46 PM
He||hammer
Sep 29, 2015 09:40 PM
Forevermore
Sep 20, 2015 01:04 PM
