RX8 weight??
Old Feb 21, 2005 | 11:51 AM
RX8rider's Avatar
Question RX8 weight??
I was just wandering how much this car actually weighs? I've seen 3020 lbs quoted in the brochure and in several threads but on the sticker by the drivers side door it says 3854 lbs. Maybe that's where the Motor Trend test (mustang vs. Rx8 vs. 350Z) got the RX8 weight. Who's right??
Old Feb 21, 2005 | 11:59 AM
ZoomZoomH's Avatar
Mulligan User
3854 is the gross vehicle weight (car + fuel + full passenger load + full cargo)
3000lbs or so is the actual vehicle weight ( varies by trim levels/fuel load)
Old Feb 21, 2005 | 01:35 PM
RX-Hachi's Avatar
From people who have actually weighed their own cars, it seems the weight is somewhere between 2920 lbs & 3020 lbs for the US versions. A Base or Sports pkg model will be lighter than a Touring or GT pkg. The sunroof and other options add weight.
I got this info from the Mazda Japan website, but I think the JDM cars are a little lighter than the US versions:
1310 kg or 2888 lbs (base/type-S)
1350 kg or 2976 lbs (type-E, which is similar to the US GT in trim level)
Old Feb 21, 2005 | 01:45 PM
czr's Avatar
czr
RX8 RX8!
How much gas you have in the tank will also contribute big time on the weight but closer to 3000lbs than 3800lbs.
Old Feb 21, 2005 | 01:58 PM
r0tor's Avatar
gas weighs about 7lbs per gallon, so 14 gallons of fuel only weighs about 100lbs
Old Feb 21, 2005 | 04:39 PM
NAVILESRX8's Avatar
FWD Hater
The JDM versions are slightly lighter because they don't have sunroofs.
Old Feb 21, 2005 | 05:27 PM
StewC625's Avatar
Insanely Yellow
3020 is the curb weight for a GT package car. In the USA, the EPA curb weight is the car empty of cargo but all fluids including fuel completely full. Gasoline weighs 6.2 lbs./gallon, so deduct that amount by your estimate of how far under full you are.
I had to find/figure this out for accurate HP ratings in playing with my gTech. I add about 190 lbs for me and tend to do those tests with 1/4 tank or about 100 lbs less gas than completely full.
Old Feb 21, 2005 | 10:31 PM
RENESIS's Avatar
Dudes........as Stew says, curb weight INCLUDES a full tank of gas. US spec RX-8s have a curb weight between 2950-3050 depending on options.
Old Feb 22, 2005 | 09:35 AM
Luftwaffle's Avatar
My touring package with nothing else weighs in at 3004 lbs.
Old Feb 22, 2005 | 05:50 PM
TrackAddict's Avatar
I miss my 'Bu
Mine weighed 3040lbs with a full load of gas.
Old Feb 22, 2005 | 06:38 PM
SantozRx8's Avatar
Raccoons SUCK!
the correct weight for a us spec rx-8 is approx.... 4826 lbs.. give or take a few depending on the relative humidity and how well the stock market is doing
Old Feb 22, 2005 | 08:18 PM
-=Rowdy=-'s Avatar
So does it weigh more on weekends?
Old Feb 22, 2005 | 10:10 PM
brillo's Avatar
Go Texas Longhorns!
mine is a base model and weighed in at 2960 with a full tank of fuel
Old Feb 22, 2005 | 10:31 PM
SantozRx8's Avatar
Raccoons SUCK!
yeah after a hard night of partying on friday my 8 ends up at around 4152lb but on a full moon its around 3000lb exactly im still tryin to figure it out gimme time....
Old Feb 23, 2005 | 09:04 AM
zojas's Avatar
my touring model weighed 2969lbs with the gas guage at 2 ticks above half. my best estimate for its full tank weight came out to 3004lbs. check out my web page, it was actually weighed on corner scales. http://desertsol.com/~kevin/rx8/rx8.html
SupraG
Sep 21, 2015 12:09 AM
Fister_Roboto
General Automotive
Aug 13, 2015 03:15 PM
MolecularConcept
Aug 5, 2015 04:43 PM
thewatcher101
Jul 21, 2015 07:11 PM
AussieGray
Jul 16, 2015 03:58 AM
